Interfacing RFID-RC522 With Arduino MEGA a Simple Sketch
40,221
32
50
Posted in TechnologyArduino
Introduction: Interfacing RFID-RC522 With Arduino MEGA a Simple Sketch
Hai there in this tutorial i'm going to help you with interfacing RFID-RC522 with Arduino Mega 2560 to read the RFID and Display the Data on the Serial Monitor. so you can able to extend it on your own
You Need:
  1. Arduino Mega or Arduino Uno (I used Mega)
  2. RFID-RC522
  3. 7 male to female jumper wires
  4. Some ID cards (optional)
  5. RFID Library (Must , Link Below)
Then Download the Below library and Add it to your Arduino IDE by clicking Sketch->Include Library-> Add .Zip Library in file menu
Step 1: Physical Connection Detail
simply connect the arduino with RFID-RC522 as shown in the above image .
Warning : supply only 3.3V otherwise module will burn out
Pin Out for Uno/Nano and Mega
RC522 MODULE Uno/Nano MEGA
SDA D10 D9 SCK D13 D52 MOSI D11 D51 MISO D12 D50 IRQ N/A N/A GND GND GND RST D9 D8 3.3V 3.3V 3.3V
Step 2: Simple Code to Read and Print RFID Tags Value
Copy the Below code then upload it on your Arduino
PINOUT: RC522 MODULE Uno/Nano MEGA SDA D10 D9 SCK D13 D52 MOSI D11 D51 MISO D12 D50 IRQ N/A N/A GND GND GND RST D9 D8 3.3V 3.3V 3.3V */ /* Include the standard Arduino SPI library */ #include <SPI.h> /* Include the RFID library */ #include <RFID.h>
/* Define the DIO used for the SDA (SS) and RST (reset) pins. */ #define SDA_DIO 9 #define RESET_DIO 8 /* Create an instance of the RFID library */ RFID RC522(SDA_DIO, RESET_DIO);
void setup() { Serial.begin(9600); /* Enable the SPI interface */ SPI.begin(); /* Initialise the RFID reader */ RC522.init(); }
void loop() { /* Has a card been detected? */ if (RC522.isCard()) { /* If so then get its serial number */ RC522.readCardSerial(); Serial.println("Card detected:"); for(int i=0;i<5;i++) { Serial.print(RC522.serNum[i],DEC); //Serial.print(RC522.serNum[i],HEX); //to print card detail in Hexa Decimal format } Serial.println(); Serial.println(); } delay(1000); }
Step 3: Simple Code for Super Market Application Using RFID
Copy the Below code then upload it on your Arduino. in the below the total purchase value will incremented when reading the card first time then decremented when reading the same for second time...
PINOUT:
* Include the standard Arduino SPI library */ #include /* Include the RFID library */ #include
/* Define the DIO used for the SDA (SS) and RST (reset) pins. */ #define SDA_DIO 9 #define RESET_DIO 8 int productname[5]={228,18,37,75,24}; int product[5]={100,120,230,125,70}; int token[5]={0,0,0,0,0}; int Total; /* Create an instance of the RFID library */ RFID RC522(SDA_DIO, RESET_DIO);
void loop() { /* Temporary loop counter */ byte i=0; byte j=0; byte k=0; int ID;
/* Has a card been detected? */ if (RC522.isCard()) { /* If so then get its serial number */ RC522.readCardSerial(); Serial.print(RC522.serNum[i],DEC);
//Serial.println("Card detected:");
/* Output the serial number to the UART */ ID=RC522.serNum[0]; //Serial.print(ID); Serial.println(" "); for(i=0;i<5;i++) { if(productname[i]==ID) { Serial.println("Total Purchase"); if(token[i]==0) { Total=Total+product[i]; token[i]=1; } else { Total=Total-product[i]; token[i]=0; } Serial.println(Total); break; } else if(i==5) { Serial.println("Access Denied"); break; } } Serial.println(); Serial.println(); } delay(1000); }
Step 4: Conclusion.,
I would like to thank you for reading my tutorial. I would appreciate if you found it useful and drop a like (favorite) or ask me anything as it keeps me motivated to do these instructables. feel free to ask any questions that you need to know...
Happy Coding Arduino...
3 People Made This Project!
  • Make it Move Contest
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
2 Questions
Hello,
Do you have a tutorial on how to write on cards with your Library, because we found the write function but we don't know how to use it.
Thank you.
Kenny FROUIN
Hi Johnson,
Could you plz advise on how to connect cables with the RFID module.Do we need to solder them directly onto the module or solder the pin headers first?
Thanks
Hazy
Dude don't solder the wire directly pin goes first or you will face lot of problems... sorry for late reply...
50 Comments
Bro its there on my tutorial above step 1...
MFRC522 or RC522 are same
Why my RFID Scanner can't detect the RFID Scanner?
Of your reader can't read your card this may be bocause of connection problem make sure you plugged in the pins correctly and check out your power supply... If power supply exceeds 3.3v it may kill the readers IC...
can i change D50, D51, and D52 to other digital pin? what should i change on the source code? thanks
No you can't if you change the pin numbers RFID will not work as it needs master slave connection....
thanks , but how could be store the read card number to simple Visual Basic 6. text box in simple form? thanks
Sorry brother i don't have knowledge on visual Basic so i can't help you i think....
create job Johnson. Its working perfect. Thanks for sharing it.
Hi, I'm having the same problem as StephenL160. The module is not reading the RFID cards. I don't see the RFID in orange on my including function. Please help.
Thanks in advance.
Sry for late check out what board you selected on the IDE... go to tools->board then select your board.... i think it will help you... honestly i cant able to figure it out the problem exactly as its hardware based,...
hi guys pls how can I register each card with a name? the card are all reading and I want to deny one of the card access because am just seeing numbers , I need help. thanks a lot for your help
Sry for late response. For achieve your goal you need to use database to map the rfid uniq value to a map read the below supermarket tutorial its very simple ..
https://www.instructables.com/id/Simple-Supermarket-App-Using-RFID-RC-522-and-Ardui/
Hi, How can I pass the RFID serial to a variable to use it in an " IF STATEMENT "??
