Internet Controlled LED Using NodeMCU
Published
Introduction: Internet Controlled LED Using NodeMCU
About: STEM Educator | Robotics Trainer | R & D Engineer | 3D Printing Enthusiast |Loves DIY Projects and LEGO
The Internet of Things (IoT) is a system of interrelated computing devices, mechanical and digital machines, objects, animals or people that are provided with unique identifiers and the ability to transfer data over a network without requiring human-to-human or human-to-computer interaction.
In this instructable, we'll be making a simple IoT project.Web page controlled LED using NodeMCU connected on a local network.
DESCRIPTION
NodeMCU is an open source IoT platform. It includes firmware which runs on the ESP8266 WiFi SoC from Espressif, and hardware which is based on the ESP-12 module. The term "NodeMcu" by default refers to the firmware rather than the dev kits. The firmware ESP8266 uses the Lua scripting language. It is based on the Lua project and built on the Espressif Non-OS SDK for ESP8266. It uses many open source projects, such as Lua-cjson and spiffs. LUA based interactive firmware for Expressif ESP8622 Wi-Fi SoC, as well as an open-source hardware board that contrary to the $3 ESP8266 Wi-Fi modules includes a CP2102 TTL to USB chip for programming and debugging, is breadboard-friendly, and can simply be powered via its micro USB port.
FEATURES
  • Wi-Fi Module – ESP-12E module similar to the ESP-12 module but with 6 extra GPIOs.
  • USB – micro USB port for power, programming and debugging
  • Headers – 2x 2.54mm 15-pin header with access to GPIOs, SPI, UART, ADC, and power pinsMisc – Reset and Flash buttons
  • Power – 5V via micro USB port
Step 1: Materials Required
  1. ESP8266 NodeMCU
  2. Breadboard
  3. LED
  4. Jumper Wires
  5. Arduino IDE
Step 2: Installing NodeMCU Board Package
  1. Open up Arduino IDE. Go to Files-> Preferences. Enter http://arduino.esp8266.com/stable/package_esp8266... into Additional Board Manager URLs field
  2. Now go to Tools->Boards->Board Manager, and search for ESP8266 and install the package.
Step 3: Pin Connections
  1. D7 of NodeMCU to LED's +ve.
  2. G of NodeMCU to LED's -ve.
Step 4: Source Code
In code
change ssid to your ssid name
and Password to your SSID's password
const char* ssid = "MODI";//your ssid
const char* password = "8826675619";//Your Password
Step 5: Uploading the Code
When u have successfully built your connection on the breadboard and write coding, you have to upload the coding into the NodeMCU by using a micro USB.
Now, go to Tools > Board > ESP8266 Modules and you can see many options for ESP8266. Select "NodeMCU 1.0 (ESP-12E Module). Next, select your port. If you cant recognize your port, go to the Control Panel > System > Device Manager > Port and update your USB driver.
Now upload the code to the board.
Step 6: Controlling the LED
  • Now open up your Serial Monitor, and not down the URL.
  • Now put the URL in your phone's browser.
  • A page will open having two buttons ON and OFF.
  • If everything is correct when you press ON the LED will light up and when you press OFF the LED will turn off.
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    3 Questions
    Hello Modi,
    First of all, thank you so much for this detailed article on ESP8266.
    I did built as you mentioned and it's working fine.
    I have one query.
    When I connect my NodeMCU and laptop to my mobile hot-spot.
    I can made LED ON and OFF from laptop and another mobile browser when all these are connected to same hot-spot.
    How can I connect from different mobile (having internet connection) and turn ON and OFF this ESP module LED?
    Mobile hotspot: having IP http://192.xxx.xxx.xxx
    Laptop is connected to this Wi-Fi hot--spot.
    Another mobile when connected to this Wi-Fi hot-spot then I can control LED
    Third mobile having data connection (from different service provider) when try to browse same URL http://192.xxx.xxx.xxx, can't open the webpage.
    Am I missing something here?
    Please can you help?
    sir,
    is it neccesary in this project that both nodemcu as well as browser must be connected to same internet network.
    how do i modify the code to be able to controll multiple leds instead of only one
    10 Comments
    Hello Modi, great project. However, I have the following problem. If I do not press a button in the browser for 10 minutes, I lose the connection. I only get a connection when I upload the code again. Do you have this problem? I would be grateful for a solution.
    Best regards
    David
    Little change in the sketch will solve your issue. I think you should make the connection to the router/hotspot in the loop() so that it can automatically reconnects if the connection is lost at some point.
    Hi David
    I am not facing such issue with my project.I'll try and figure out to solve your problem and come back with the solution
    That's great! Many Thanks!
    Very nicely drafted !
    What if I want to control multiple leds and have different buttons for each of them like I can control each of the led separately ?
    Hi Modi, I do exactly what you say in this post and i have done uploading. Then, i have this problem in the following picture. Btw, thank you for this great project. Hope to see your reply soon.
    Please change the baud rate of serial monitor to 115200
