Step 2Entering Administrator mode on your EVO
When you turn it on the EVO it will auto boot into the fairly limited User acount and before you can do anything you need to get it into Administrator mode to do this once it is up and running press Tab Home End Left arrow<- Right Arrow-> keys in Quick succession. This should spawn the Login screen
Change Default User Name from User to Administrator and default Password ( User) to Administrator (Both Case sensitive!) and should swap you into Administrator mode. On XPe the Tab Home End left Right 5 key sequence is changed to a simple Press and Hold the Shift Key while Logging Off ( and On again automatically ) User password sets are the same . At this stage all changes are temporary as the Flash drive is still locked and if you restart or reboot you will be back where you started . So you need to Unlock the Flash which is the next step
Add Comment
