Interphone ESP8266 2 Components Only < 4$
Introduction: Interphone ESP8266 2 Components Only < 4$
I suggest you to open your door or building door remotely with WiFi, I do that because I'm bored to get my keys out of my pocket, and it's more fun and you win some time.
If you have any questions go comment, i will reply fast as possible.
Don't forget to vote if you think it's a good improvement! I participate in the contest "Fix it". Thanks
Step 1: What You Need
For do that you need 2 components
Step 2: Connections
Connect all components together like this :
Phone charger + to 5V Wemos
Phone charger - to G Wemos (GND)
SSR - to GND
SSR + to D5 Wemos
And connect the AC signal from interphone to SSR PIN 2/1
Step 3: Have Fun
Compile and download the code to ESP8266 with USB and for future upgrade use OTA :-)
Connect to you ESP8266 with giving ip address and control the door.
I know my code can be improved ( Timers ) avoid delay on "discret" function but I will do quickly and i would like to share with you.
I think i will improve this project to add the buzzer detect and control it, to do not disturb me nightly or too earlier.
And add the door magnet detector to enable/disable email when my door is open when i'm not here.
The old phone charger is behind the light switch :-)
Note : Sorry for my english, i'm french and my english is not 100% perfect.
Step 4: Optionnal - Widget on Android
To open the door even faster you make a widget who do the http request for you.
Download the Http Request Widget APP
And configure this your ESP8266 IP replace the by your IP.
On iPhone you can add a website in your home screen, do with /discret or /opendoor URL.
If you cannot connect to your WiFi network and you have a data plan with your mobile, you can configure a redirection port on your router, but be careful to expose your esp8266 because it can't handle alot of clients, and is quite dangerous. I suggest if you have raspberry use Nginx proxy and limit and protect with auth.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
