Active Camera Tripod by Edouard67
Contest Winner
[   Category: 18+  ]
Digital cameras are wonderful devices making experiments with images very easy.
You might dream of features that are not available in your camera menu.
This project helps you realizing the following:
- cylindrical or hemispherical panoramas
- stop motion animations
- night photography
It can be used “headless ” (no computer attached).
Pictures will be available on camera memory card for computer processing.
This instructable provides drawings and arduino sketch.
The provided sketch (firmware) can easily be upgraded by anyone to provide more features.
You will need the following:
    base
        - 3x small wheels
        - thin panel either wood or acrylic (e.g. plywood, MDF, Medium-density fibreboard)
        - 2x standard size servos (e.g. Futaba S3003)
    head
        - more thin panels
        - 1x micro servo (e.g. Futaba S3107)
        - “L” brackets (e.g. ~2.5 inches or 6 centimeters)
    electronics
        - Arduino 2009 (aka. Duemilanove) or latest model
        - Arduino Sensor Shield (i.a. grid pin header connections)
        - LCD (HD44780-based) + cable + connectors (prefer backlit LCD)
        - buttons + prototype PCB + resistors + cable + connector
    tools
        - laser cutter (for the luckiest)
        - drill,
        - saw,
        - sandpaper,
        - pen,
        - cutter (for the others)
        - soldering iron
    other
        - bolts and nuts
        - threaded rot and wingnuts
        - wire
        - adhesive tape
        - bolt to attach the camera (0.25”)
    optional
        - buzzer + cable + connector (beep before a shot)
        - photoresistor + cable + connector (light -> exposure & lcd back-light)
Step 1: Build the base
Print the drawing without scaling it.
    - insert the jpeg-drawings in your favorite editor
    - set or keep the image size at 100%
    - set your printer driver’s scaling option to “None”
    - check the printed scale with a ruler (inches or centimeters)
        (adjust and reprint if necessary)
Use a cutter to have adequate marks
Stick the paper on the wood panel with adhesive tape
see picture
Draw more marks
see picture
Saw and drill
gpirmez says: Jun 25, 2011. 4:57 AM
How did you attach the servos to the camera-holding structure??
Edouard67 (author) says: Jul 3, 2011. 6:50 AM
Hi,
I attach the structure servo with small wire thru the servo arm and the L bracket.
I attach the base servo with small screws.
The servo on the shutter is held by "colson" (plastic clips).
Thx for your interest and sorry for the delay.
FourthDr says: Mar 23, 2011. 1:58 PM
I found the maker: Shenzhen, China. Everyone selling this item does so through a generic website with no US address and wants either Paypal or a bank transfer to China. Not something I'd be willing to do. On top of that, the design is not open. Never mind an eagle cad file, they don't even have a schematic available.
I think this would be an excellent opportunity to make an open shield similar to what the Chinese are selling. But with a schematic and eagle cad file included for download. Especially since all the shield seems to do is bring Vcc and GND out to all the Arduino data lines with either headers or some other type secure locking connectors.
I'll post a link here if I get around to designing something similar. In the mean time, think I'll just use a proto shield or bread board.
Edouard67 (author) says: Mar 23, 2011. 2:53 PM
Yes, the "servo shield" I bought was "made in asia". I don't have the precise location... I sometimes pay with Paypal which allows refund (no problem so far).
Yes, it would be nice to have the same shield "open source" if it isn't yet. I really don't know about the licence or available files.
My purpose wih this project was to have fun (and to workaround the soldering as much as possible).
Sure, breadboard or anything similar would be ok.
You might have to patch the sketch (using 3 servos, 1 analog keypad, 1 LCD). Simply locate/update the lines starting with "#define PIN_" to match your choices.
FourthDr says: Mar 23, 2011. 11:39 AM
Where did you get the "servo shield"? There are at least a half dozen shields that fit the servo shield description. But non I could find in a google search turned up the one pictured. Who sells the above pictured shield and is it open source hardware?
Edouard67 (author) says: Mar 23, 2011. 12:35 PM
Thanks for comment!
I didn't noticed there were so much shields http://shieldlist.org/
I used the "Sensor Shield V4" search http://www.google.be/images?q=Arduino+sensor+Shield+v4 for this *wonderful* shield; I mean we don't need soldering skills ;-) This is a plug'n'*have*fun* !
I don't find it directly from http://shieldlist.org/
If you can wait, I suggest e*Bay (search "arduino sensor shield").
Edouard67 (author) says: Mar 23, 2011. 12:48 PM
Oups! (some details are only available in the "sketch" source file)
Check for "#define PIN_SERVO_"... in http://www.instructables.com/id/Intro-Active-Camera-Tripod/step10/The-software-sketch/ for details.
Digital pin 4 --> base servo
Digital pin 5 --> head servo
Digital pin 6 --> servo on the shutter
zazenergy says: Mar 16, 2011. 6:43 PM
wow super interesting camera tripod. could this be used similar to a gigapan?
Edouard67 (author) says: Mar 17, 2011. 1:26 AM
Thanks for your comment !
I haven’t tried a gigapan so far.
As a *quick* patch, I suggest to add an “zoomed panorama” option to the main menu (see function loop()).
Copy the optionMenuPanorama() function, rename it and update the increments in the “for” loops.
Set these increments to smaller values matching your focal length.
The whole process (shooting and stiching) would be slower… But it should work.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
