In this tutorial we are going to make LED Christmas Lighting based on the Arduino prototyping board. The Christmas lighting will be based on 20 LEDs. This project is going to be both relatively cheap and incredibly awesome. We will be using a technology called Charlieplexing which is frequently used in Arduino based projects. The reason for this is that we do not want to use a pin on the Arduino board for every single LED.
Remove these ads by
Signing UpStep 1More on charlieplexing
For a LED to work you need current flowing from HIGH to LOW. For example to make LED1 burn PIN1 is HIGH and PIN2 is LOW. However the state of PIN3 could influence this schematic. Therefore in charlieplexing every unused pin goes into what’s called a tri-state, setting this pin as an INPUT. Those have very high impedance therefore very little current will leak out there.
Example: To turn on LED6. PIN1 is LOW, PIN2 is INPUT and PIN3 is HIGH
This technology is not very impressive when only using six LEDs, however when we expand the amount of pins we discover that this system can connect {pins(pins-1) = LEDs} in the case of 5 pins this is 5x4=20 LEDs, exactly the amount we want.
here is a video is still got lying around. I do not have anything better at the moment! Please tell me how the project went for you!
Kind regards!
