3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Control an OWI Robotic Arm with Arduino
Step 2Attach the sensors
Attach the sensors
  • last photo ←
Each joint needs a potentiometer to measure its position, for "closed loop" feedback control. In the pictures here, I've shown a number of different kinds of pots, ranging from big metal ones to little "trimpots". In the intro, I linked to these, which are good general-purpose pots, but if you want smaller trimpots you can use these, which are shown in the arm picture here. I tend to use 10k pots, but you can use whatever you've got handy--just change the input thresholds in the Arduino code in the next section as appropriate for whatever readings you get.
Each pot has three wires: +5v, GND and variable. You'll connect them to the Motor Shield analog pass-through ports as shown, with the variable wire closest to the edge of the board.
On the Adafruit Motor Shield I've soldered three rows of break-away pin headers for the variable, +5v and GND pins on the shield here. You can cut off one plug of your jumper wires and solder it to each connect of the pot, and plug the other one into the Motor Shield. Or, if you have some RC three-wire cables around (like these female-to-female connectors that I've used here) , you can just cut them in half and use them for less wire clutter and confusion. The Motor Shield pins aren't quite the standard spacing, so you have to bend them a tiny bit, but it's no big deal.
In the picture, I've attached the base rotation sensor with some standard 22 gauge metal plumbers tape that you can get in any hardware store. It's pretty easy to bend it, cut it and screw it into the OWI Robotic Arm, either using existing holes or drilling new ones for small metal screws. I used a small length of wire to go through the slot in the pot and the holes in the plumber's tape to keep the pot shaft stationary as the pot body moves beneath it with the motion of the robot arm joint.
For other arm joints you can solder the trimpots into the perfboard as shown in the picture and hot glue that to the OWI Robotic Arms joints. Then hot glue some stiff piano wire onto the trimpot thumbwheel and connect it to a stationary point of reference for that arm. I typically use a small bolt as the anchor point for the wire, as shown in the pictures, so it can move back and forth bit without stressing the glue joint on the trimpot wheel. That's also the case for the bottom one, where the wire can move up and down in a hole drilled in the plastic base.
Note: there are many different and good ways to attach the sensors--these are just the way I did it. These work well, but you can mount them any way you want as long as they have a clear range of motion.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:zlite(DIY Drones)
Founder of DIY Drones and 3D Robotics. Editor in Chief of Wired Magazine, author of the books "The Long Tail", "Free", and the forthcoming "Makers". Founder of GeekDad and BookTour Father of five...
more »
