Intro to Product Photography (for instructables)
This instructable is meant for anyone making an instructable or slide show who can't seem to get good pictures, or is always criticized about their pictures. These particular tips are intended for shooting small to medium sized projects that can be maneuvered relatively easily, and put in a studio environment. But even if your particular project doesn't fit these criteria, many of the tips I'll be giving are universal, and can be applied to any photographic documentation.
In most projects, it's not practical to take the pictures for each step in front of a backdrop with proper lighting. In these cases, it's often still good to take pictures for the intro slide like this. A good intro picture will attract many more viewers.
Step 1The Camera
The Camera
Please try to refrain from using cameraphones or web cams. If you absolutely have to, be sure to have plenty of light, and to rest the camera on something to keep it steady.
Other than that, most cameras should work...use the best one that you have access to. If you don't have access to any cameras, one suggestion is to buy a disposable one, use it, and have them scan the images onto a disk.
« Previous Step   View All StepsNext Step »
65 comments
1-40 of 65next »
Jul 31, 2009. 9:55 PMstrcrusher says:
lol you have the same whistle as my friend
Mar 24, 2009. 9:51 PMGorfram says:
...take... ...the... ...photo... ...from... ...directly.... ...above...
... mind blowingly self-evident, but I would never have thought of it in a zillion years - thanks mucho!
Jan 19, 2008. 12:12 AMkillerjackalope says:
A great Item I found is the sunlight bulb, it's a CFL bulb that's usually around 25 watt and puts out really brilliant white very close to the colour temperature of sunlight, whether it's an SLR or a webcam it makes a big difference and seems to help with autofocus (even I don't get that bit of it) that and if you pick up a few cheapy canvases add some tape and a good bulb, I suggest fluorescent becasue the output is clearer with that than incandescent bulbs. You make a box with an open side and no top, place your object a few inches away from the back and if you have an adjustable flash unit then aim it directly at the object with triple folded kitchen paper as a 'muffler' (I like that term) and put the bulb so the majority of light is falling behind the object you get pretty good definition and also any textures etc will have some contrast because there's slight shadowing. another useful trick is using a room with a low ceiling or a big cardboard box painted white inside and directing the flash straight up or to directly above the objects.
Oct 21, 2008. 5:35 AMfegundez1 says:
you can get the "sunlight bulbs" at the grocery store they come in almost every conceivable style.
Oct 21, 2008. 5:55 AMkillerjackalope says:
Aye but the incandescent ones are pretty rubbish compared to the CFL ones...
Jan 20, 2008. 5:07 AMkillerjackalope says:
I found them at B&Q which is pretty much a hardware store...
here's a link
Also on the way to one for you (I see Uk pages first) I found that you can get daylight bulbs that produce negative Ions at the same time, by the way those seem a bit pricey if you hunt about a bit you can get them really cheap. Lifetime seems to be about 3 years and running
Jan 20, 2008. 2:49 PMkillerjackalope says:
yeah I liked it, also i had heard negative Ions are good but didn't no they helped bad smells...
Jan 20, 2008. 1:16 AMPatrik says:
Even better - REAL sunlight! Great lighting, ideal for macro-photography... There's a reason why almost all TimAnderson's pictures for examples are taken outside in the sun. Might not be quite up to scratch for "product photography", but it's a great solution for a nice DIY instructable...
Jan 19, 2008. 12:46 PMKiteman says:
Try sewing shops - embroiderers use them when working after dusk.
Jul 31, 2008. 1:30 PMdjsc says:
nice. I've had a few tries since reading this, having some trouble; any suggestions what kind of lights to use? I tried halogens and they weren't as white as I thought they would be. Also not enough light on the subject with 2 60Watt bulbs and reflectors.
Aug 1, 2008. 12:46 AMknarx says:
Sorry, I am not a native speaker, so if you meant white with "white as I thought" try the white balance on your camera. If you meant bright with "white as I thought" use a construction spotlight, you can get in every hardware store for a few buck. Be careful, they have 500 Watts and can become very hot. With them you also have to use the white balance on your camera, but brightness should be no problem anymore.
Aug 1, 2008. 11:55 AMdjsc says:
yeah, thats what I meant. thanks for the tip knarx.
Jun 26, 2008. 7:35 AMDerin says:
I am gonna so try this!pics coming soon
Jan 20, 2008. 10:45 AMBran says:
Is it possible/plausible to build a black lightbox? Nice Instructable!
Jan 21, 2008. 4:43 AMPKM says:
You can put a black backdrop in a lightbox- I did this for some funky low-key-ish photos of dark shiny things, only lighting the lightbox from the sides and underexposing to get side highlights. I would link to the examples on my Flickr account but that's too much of a shameless plug even for me to do on a comments board- if you're interested then PM me
Oct 29, 2010. 5:22 PMBran says:
Well, now that I think about it, I'm not quite sure. For light-colored subjects, I suppose. By the way, I signed up at Phodeo - nice site!
Jan 19, 2008. 6:37 AMKiteman says:
Good piece, W'berg.
We should get a rash of better pictures now ...
(Yes, I know all my pictures break your rules, but Shed would sulk if he didn't feature in my 'ibles)
PS - am I the only one amused by step 4's self-referential image? A macro shot of a macro function...
It must just be me, then
Jan 20, 2008. 5:08 AMkillerjackalope says:
I like that but would prefer a macro shot of a camera doign the macro shot...
Jan 19, 2008. 7:40 PMJohn Smith says:
*gasp* YOU NOTICED THAT TOO?!?!?!?
I thought I was the only one who noticed that macro thing...
Jan 19, 2008. 10:49 AMzachninme says:
META-MACRO SHOT :D Sorry :P
Jan 19, 2008. 12:49 PMKiteman says:
True, but I was thinking mainly of all my shots lit by fluorescent strip-lighting on a green cutting mat with white markings and a background like my workbench ...
Jan 20, 2008. 4:15 AMKiteman says:
I realised that - why not edit the comment into your final step?
Jan 19, 2008. 6:09 PMboringhistorygirl says:
haven't heard of picasa before. great tool! i use photoshop at work, but have always resisted spending the money to have it at home, which means me wasting time at work editing personal photos to upload. at least now i can do some of the editing at home.
Jan 19, 2008. 4:30 PMDr.Professor_Jake_Biggs says:
Next 'structable: How to pornograph? xD Seriously though, excellent tutorial, I'll use your tips for backdrops for the next time I come up with something genius. But you forgot one thing. How does one take excellent pictures of themselves with the camera pointed directly at his/her-self? hehe.
Jan 19, 2008. 5:14 PMDr.Professor_Jake_Biggs says:
Well spoken and too true. lol
Jan 19, 2008. 3:39 PMjaysbob says:
nice instructable. you might want to note though that white backgrounds will usually turn out gray if their not lit separately. Not a huge deal but it gives things a much more professional look if the background is bright and crisp instead of a muddled grayish color.
Jan 19, 2008. 12:09 PMKeith-Kid says:
Nice
Jan 19, 2008. 11:13 AMLinuxH4x0r says:
Great instructable. I can take great pictures, but my main issue is lighting. I never use flash, unstead I adjust shutter speed or use other sources of light.
Jan 19, 2008. 9:17 AMrobbtoberfest says:
Great stuff! I started using my white enamel bathtub for a background recently, works real nice when the tub is clean.
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
147
Author:Weissensteinburg
I enjoy photography, horticulture and carpentry, and am almost always doing something relating to of those things. Feel free to send me a PM for whatever reason.
