3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make newspaper logs for your fire
You can make fuel for your fire by using newspapers. This instructable shows you how to make a newspaper log in less than two minutes. The video shows you the whole process.
It's kind of like hardcore paper mache. To get a solid log, you must change the structure of the newspaper. That is from sheets to pulp. Usually there's no shortcuts in paper mache, but you'll learn how to make these logs very quickly using a rubber mallet.
The paper logs burn best when combined with wood. They will create more ash than wood. The hole through the middle will help it to burn and make the drying out process quicker.
Step 1Prepare the newspapers
You will need newspapers, a strong bucket, a rubber mallet and a dowel about an inch thick. You will also need a concreted/cemented area to work on. Fold the newspapers and put 3 or 4 into the bucket and cover with water. The newspapers will probably float to the top so put a piece of wood on the papers.
If you have a leaky gutter with a bucket under the drip or collect rainwater in a tank it would be a great idea to use rain water for the logs.
The newspapers in this instructable were soaked for two days. One day is enough. If you want to speed up the softening process put a squirt of cheap detergent in the water.
wingbatwu suggested adding flour to the water which sounds like a really good way of helping everything bind together.
211 comments
1-40 of 211next »
Aug 4, 2011. 12:14 PMjbenfield1 says:
The nice thing about using old paper for fire is that you aren't restricted to log shapes. By using some clamps, two boards and some wax paper (to line the boards) you can make paper boards, strips, etc. My boyscout group did this but we soaked them in gasoline rather than water and let them dry in a dry, well ventilated, room that kept a temp of about 90 degrees in our scout house (it was an old kitchen that had four vent hoods we turned on).
Apr 5, 2012. 9:27 PMmtaylor22 says:
That is a very bad idea, but you can make very useful fire kindling sticks, from rolled pieces of folded newspaper, dipped in candle wax from old candles. Heat the wax in an old pot, near a campfire, and dip the papers in the wax with old salad tongs. When they cool, they will stay dry and sealed, and light easily with matches. Tuck a few under your fire wood and kindling, and they will help start your campfire or bbq.
Mar 27, 2012. 3:48 PMCosantoir says:
I'm sorry, but that is criminally INSANE and STUPID.
You shouldn't be allowed within 100 yards of Boy Scouts if you think that soaking paper in gasoline and then drying the gasoline soaked paper, INSIDE A BUILDING, with MULTIPLE ELECTRIC FANS RUNNING, is a good idea.
Here's a hint: call the local fire station, describe your process, and see what they have to say.
May 22, 2012. 12:16 PMXin666 says:
You know, he didn't say that he was leading a boyscout group.
Apr 1, 2012. 6:40 AMcool2000 says:
86 f is hot?!
Mar 24, 2012. 9:38 AMjimsmithkka says:
Dont know if its been said yet, but you should probably never use these for an indoor fireplace, paper is really bad for those, but a great idea for outdoor fire pit/camping/newpaper recycling alternative
Oct 31, 2011. 7:16 PMcircuitfish says:
I've found you can also make some really nice fire-starter/filler material by grinding up the newspaper instead of pounding it out and baking it in the oven to get a sort of "chip".
Aug 23, 2011. 2:16 PMrwoodward1 says:
Newspaper is not bleached. If using white paper bothers you, use newsapaper. No harmful fumes given off (even from white paper).
Jun 26, 2011. 12:38 AMscabeleira says:
Hey i made one log but i also made a small one to test it out but i have a problem keeping the flame alive is it meant to just smoke up ..... Or is just because it is small? Help!
Apr 28, 2009. 8:41 PMJohnMichael says:
What purpose does hitting it with a mallet serve?
May 13, 2011. 10:08 AMjacevedo says:
You can also use the blender...or dance on top of it, as in making grape wine... 8-)
Jun 1, 2011. 1:48 PMDAND says:
Just don't fall... Especially if you are a news reporter...
Jun 10, 2011. 8:26 PMtictaclad says:
rofl
Jan 10, 2011. 1:23 PMlebeef143 says:
Hi there,
I really like your idea and appreciate the concise way you have presented it. I'm wondering about the duration of the burn on these logs? How long do they burn if they are by themselves?
Mar 27, 2011. 1:05 AMblobby123 says:
I'd like to be using the paper that gets recycled from my office, but what do I do with the water which has been used to soak the paper? I dont think it would be very eco to tip it down the drain, and I dont want to dig a hole in the garden and tip it in there either.
Settling tank? Sand filter?
Dec 26, 2010. 8:40 PMwingbatwu says:
I would add some flour to the water to make papier mâché glue
Dec 23, 2010. 9:52 AMjoeny1980 says:
I read thru all the comments on here, some are pretty old so I didnt want to comment against them. I really like this idea, I like the idea of doing something to make them look better. For example wrap the last layer with a soaked brown paper bag - to make it look at least brown instead of white.
Someone suggested adding a layer of coffee grounds - i like that idea also. I wonder if you just dumped a few cups of used coffee grounds in the water if that would disperse well and sort of soak in. It may also help to dye the paper to a more natural color. I imagine it would give a nice smell when it burned and they mentioned it may help with achieving a better burning temperature.
I was thinking maybe tossing in some pine needles in between some of the layers to add some crackling.
There is alot of arguing on here about the environmental aspect of this and that burning paper is worse than wood, etc. But one point I didnt read - is that this isnt an alternative to wood necessarily... this is an alternative to a Duraflame (or other brand) log. Which as far as I know, those are made with pulp also. So rather than comparing this to wood - if you are environmentally conscious, I'd be curious how it compares to a Duraflame. Because thats all this is, a DIY Duraflame.
Dec 23, 2010. 7:57 AMwerfu says:
Using these as a fire started shouldn't be a problem, but would burning a lot of them cause creosote formation into the chimney? Newspaper burns at lower temperature than wood and release more soot and pollutants. I think something should be added to guaranty a high temperature burning. It would also improve it's fire starting capability.
Dec 23, 2010. 12:32 PMdanielflugt says:
This is brilliant! I was going to get a paper shredder for those sensitive documents (I don't like the idea of data on me lying on some landfill), but this is much better. I'd still recycle whenever possible though.
Nov 27, 2010. 11:01 AMkraskoy says:
I am wondering if anyone has tried this with other types of paper? I'm trying to figure out what do with all all our paper feed sacks, and thinking this just might be the thing to do. They aren't as 'soft' as newspaper, but will they hold just as well? I currently tear them into 'balls' and use those to try to start the wood, but if I could make logs out them, it would probably be a lot easier. Thanks.
Nov 16, 2010. 7:14 PMDrewManchu says:
Nice! I like simple but efficient ideas! And working in the medical field, I always have a pair or two of latex gloves around to keep my hands clean!
Sep 16, 2010. 5:10 PMcronama says:
what about drying it in an oven ,as if you where to dry clay
Jul 7, 2010. 7:41 AMgreenroofer says:
It's a very clever idea. I was put off by those pricey fancy briquettes makers. The mashing step can be therapeutic. Pity my log store is already full!
Apr 23, 2010. 1:30 PMBonifaceJ says:
Would this work with shredded paper?  My office goes through so much, if I made a mold and soaked the shreddings  a bit, then pressed it in, I wonder if that would work?  I love using my fireplace and always have a shortage of logs, and my roses and blueberries like the extra ash I fold into their beds.
Mar 20, 2010. 3:17 AMfreejelly says:
I've also added used coffee grounds which I got from from Starbucks in the logs to make Java Coffee Logs.
Before pulping the pages together, I sandwiched a layer of coffee grounds between a few sets of pages and then pulped them in together. Apparently coffee grounds burn hotter and cleaner.
You can also blend in other things like sawdust, toilet paper cores, egg containers etc...
Be creative. Try different things.
Dec 26, 2009. 3:36 AMPhoghat says:
This is a good instructable.
We have had enough comments on whether they are good, bad or indifferent towards the ecology.
PLEASE STOP ARGUING you're giving me a headache.
Mar 20, 2010. 2:52 AMl3owzaaaah says:
Not meaning to lash out or anything, (it's hard to get feelings across on the Internet), But I think if you had just left pickford to believe that this was harmful, this 'conflict' could have been prevented.
Mar 20, 2010. 2:49 AMl3owzaaaah says:
To end this stupid argument, yes burning paper is harmful, but then so is burning anything. Yes, sometimes recycling isn't always what it seems.(In sense of recycle plants being full and paper going to land fills) No this is in no way 'wasteful'. And finally think of recycling as a privilege, if it's there use it, if not don't. I hope you guys stop arguing now. Kthxbi
Mar 19, 2010. 10:02 PMfreejelly says:
My wife does not like "toilet paper looking" white rolls sitting around the fireplace so I've started making them a bit more better looking by wrapping leaves, bark or other dried organic material in the final stage. I put a final coat of dried leaves or bark on the outside and the logs look more natural.
You have to try to stick the dried leaves and bark on tightly by pressing them into the pulped paper.
The look like real logs sitting next to your fireplace.
I will try to get some images.
1-40 of 211next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:bauble
