3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making a cheap recording studio!
This is how you make a recording studio on the cheap. Mine cost about ý1200 but i have loads of extras that you don't really need. I'm guessing you could get one going for about ý200 if you have a computer. Or if you really need to go cheap you could make one for about ý5 if you have a microphone already. This is ideal for people who need high quality recordings quickly and cheaply (if that's a word)
I used this studio to make this music video
Step 1What you'll need
What you\
Basics:
USB Mixing desk (i used a Alesis 8 track) from maplin electronics for 100 quid.
Computer (i use a macbook white) for ý700 and odd
Speakers (i use a marshall amp and an Ashdown bass amp) which I just had
Other stuff
Acoustic guitar need condenser microphones. I got mine from maplins for 15 quid.
Drums need drum microphones. These are rip offs and i don't have any ;)
Electric guitars and Bass's can be plugged straight into desks as well as powered acoustics but it's best if it runs through an amp first (although garage band has amp effects and the desk has 100 built in effects)
If your a right nerd:
I use a big ass rack effect running for the sake of it
Also, I have a tape recorder running through the Tape in/out on the desk
And another computer (and it uses sony acid) which i use for making 'buzzin' rave songs :D
25 comments
Oct 4, 2011. 8:11 AMhighvoltageguy says:
im makin one but i used an alto zmx52 mixer
Jul 6, 2011. 3:05 AMsiddiq4321 says:
this siddiq , India,
i have a very cheaper and working method :
1)use the software flexi music orchestra - a very user friendly software to play wav. files etc. on the keyboard
2)download yamaha / ronald / alesis drum samples over the net or from torrents ...they are very quality one and ull have no complaint
3)load all these sample to the key u want for EACH drum/cymbal ...which is pretty lengthy and save it ..
4)then comes the hardware ...use and old PC keyboard -ic ...or if u get confused with the ic pins j...just keep it attached to the plastic sheets which are below the keys ...and the pass out a pin ter . rhe conductor holes ..which is again a time taking job ..but cheap and working
5)now on other ends of the wire ..anttach a piezo...which is the cheapest drum trigger ..of if u r keyboard does not get enouhgh gain on tapping ...the attach 2 /3 in series and keep one above another ,,....and place it beneath the mouse pad (to experiment ) ..the strike u r mouse pad to play ....
was it helpfull ?????/////////////////////////
don't forget to tell me how was it .....
Replyflag[delete]
Apr 14, 2011. 4:00 PMMetal4God says:
This is how I do it
Macbook White and usb mixer for the producer
10 feet away is my 4x4 recording room with foam lined walls with mic
and a 24 inch monitor so I can see the timings as Im recording
I use acid to record
and FL studio for the beats
Mar 12, 2011. 1:51 PMonlinemastering says:
Mackie VLZ3 desk have very quiet microphone preamps on them.
Interesting and thanks for sharing.
online mastering
Jun 20, 2010. 2:53 PMAlternateLives says:
Don't you need a Direct Box for "unamped" guitars? (those boxes that convert an unbalanced signal to balanced) if you want a kick mic, buy a small, cheap speaker, play some loud music through it for a little bit, then solder a mic (XLR) male end to it. attach the speaker to a stand. presto! Cheap ghetto kick mic! also, the Shure SM57 is a good instrumental mic that you can probably find on the cheap at some sites. if you really want to go cheap for drum mics, a Shure PG48 or SM58 with the top removed should work nicely. PG48's are cheaper. I've seen PG48's for as low as 30$.
Jan 7, 2009. 4:28 PMdchall8 says:
When you start hearing things in your recordings, there are some Instructables on making quiet rooms. What is the exchange rate? How many quid to the sawbuck? ;-)
Jun 11, 2010. 12:27 AMLance Mt. says:
How about we DIY it? Then just software the rest?
Nov 18, 2009. 2:27 PMshreiber says:
You can use sound control acoustical products as a DIY and get a professional soundproof recording studio. In addition when using a damping compound like Green Glue you actually enhance the sound in the room as the vibrations are controlled.
Aug 12, 2009. 5:26 AMhoihoi151 says:
if u want a quiet room you need to condition it. dont sound proof it. get a few wooden frames. like large canvas frames. stretch a soft fabric across the front and fill the frame with little bits of foam. then add a wooden backing. mount them off your walls about 6 inch. mount in places of noise reflection, ie corners, concrete, anywhere the noise bounces. also put as much sound absorbing stuff in the room, big pillows, sheets, Lots of hanging clothing (like a clothes line) is brilliant. glass is also good at absorbing sound but make sure it doesnt rattle. any more questions email me
Mar 18, 2009. 12:00 PMbustedit says:
ive seen alesis 8's going for 150-240, less used
Oct 12, 2009. 5:18 AMarrayanimation says:
What films do u make that you overdub
by the way great instructable t has really helped me thanx
Jan 7, 2009. 4:12 PMjonslilbro says:
Just thought I'd add on a bit about phantom power. Alot of mics don't need phantom power. What it is, as it is sometimes referred to as, is +48V. Alot of mics that are smaller need an extra push of power and that's what phantom power is for. Always test a new mic WITHOUT phantom power, before trying it with as you could overload the mic, and that wouldn't be a good result. Also, if you are going to enable phantom power, make sure you have your system muted, otherwise you'll hear a pop and it's just not good for any speakers that are attached. Other then that, nice job.
Aug 12, 2009. 5:12 AMhoihoi151 says:
phantom cant really damage dynamic mics. phantom is only needed if your mic is a condenser, to charge the plates inside the mic.
Aug 12, 2009. 7:07 AMjonslilbro says:
I didn't say it WOULD, as more I said it COULD. Older mics, even dynamic mics, have a center tap of the transformer grounded, which could cause the phantom power to short the transformer.
Aug 12, 2009. 5:21 AMhoihoi151 says:
OMG. if you are going to build a basic home studio save a few $$ and buy PROTOOLS!!!. I work on a macbook as well. but i dont touch garage band. yes its a good program if u cant afford editing software. but if u can afford a mac in the first place u should have the money for protools bundled with the Mbox2. or get a 003 rack instead of the mbox. Protools in infinitely better than garageband in everyway. when leveling your tracks u want the peak to be just under the top of your level bar. if u dont u will need to jack up the volume in the mix and thus increasing the noise floor (hiss). also even the best sound card will sound RUBBISH compared to an mbox. and get good headphones. if you are going to make a small recording studio ur minimum requirements are. PROTOOLS!!! with an Mbox2. good headphones. good cable. and a Shure SM58 mic. i understand your still in school and all but i just finished school last year. and am running a studio in australia and doing live tours. trust me you songs will sound worse through rubbish equipment.
Jul 28, 2009. 8:59 PMdjebonix says:
I found a one stop info shop, and saved so much money building my home recording studio. You would think I spent thousands with the quality I’m getting. Check out the site http://www.cheapstudiobuilder.webs.com
Jun 20, 2009. 3:22 PMJ2aper says:
You don't pan and peak your volume lights, you pan and peak your audio signal, left or right in your stereo image.
Jul 28, 2009. 3:50 PM23r0c001 says:
I believe he meant "Pan" and "Peak Volume Lights", as if to say that there is a pan knob and a peak volume light on each column. The words just weren't separated well.
May 4, 2009. 1:27 AMmusicman813 says:
Building a recording studio on the cheap is going to cost you about $1000 American dollars. My studio conisists of a HP multimedia computer with 800MB ram and a 2 gigahertz processor, with two 7200 rpm harddrives, with a 2.0 USB port. To get music into this computer, I use the Tascam 122L USB interface (connects to the USB bus). The interface allows you to record guitar and professional balanced microphones that use phantom power (supplied by the Tascam interface unit). The Tascam came bundled with Steinberg Cubase LE recording software, which completes the studio. From that point on all you need is your imagination, and a quiet day!...oh, and don't forget, talent!
May 1, 2009. 7:39 AMcwebsterlusk says:
wow, i have the Alesis Multimix 16 USB, other than being bigger the difference is it has slides for volume. great little pieces of equipment by the way, i bought a set of Audio-Technica ST95 Mark II mics and they work great for drum mics. 5 of them were $99 USD from bswusa.com Just buy a cheap kick mic and you're set
Feb 20, 2009. 5:36 AMkerberoszero says:
Man, i got a macbook white too and i'd like to record something with my electronic drum using line in (the jack next to phones jack) ,but it keeps on recording with the built in mic...what can i do?
Feb 16, 2009. 4:05 PMcarlos-felo says:
It's very good...
Jan 13, 2009. 4:45 PMstarwing123 says:
If it me, or does this look very similar to the room in this instructable.
Jan 8, 2009. 6:02 AMgmjhowe says:
Nice, thats what i would call a ghetto studio. My friend Built himself a proper studio in his garage, with a window, and sound wall and everything.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:connorbennett(My iTunes video Podcast)
I'm Connor. I play drums, guitar and make films. Have a look at my instructables, and watch my videos. I'll get a link up for my band when I get around to it. :)
