Someone gave me a cordless circular saw with a dead battery and no charger. So I could pay $150 for a new battery and charger, or I could take the battery from my Mikita drill that would work fine and run it off that. You'll need:
wire strippers
soldering iron
screw/drivers of several types
cutters (dikes)
$9 auto-ranging probe I love you Harbor Freight
wire
solder
duct tape
beer or perhaps the kindest kind
Step 1: Will it work?
I am not happy with this at all. The battery only last a few minutes. I am going to put a cord on it. A 12v 1.5 amp ac adapter barely spins it. The battery charger senses it not hooked up to a battery and does nothing. Maybe I could I could increase amps by putting several smaller transformers in parallel?
Dewalt is no help at all "This saw is designed to run using DEWALT 18v batteries, we do not recommend using any other power source for this saw. We do not have any other motor specifications for this unit." Liar...oops did I say that out loud?
Step 2: Determine polarity
Step 3: Take the donor battery apart
Step 4: Connect the plug
Step 5: Make a battery connector
Step 6: Solder the battery connectors
Step 7: Put it together
Step 8: Done, sha-shaw, it works
Plenty of duct tape so you don't short it on something.
The saw runs great and cut 3/8 plywood well. It will stall if you try to start the cut too fast but once you're moving it cuts nicely.
Visit Our Store »
Go Pro Today »
Say your 14.4V drill uses 500W. The current in that case is
500W / 14.4V = 34.7 amps. '
If you then drill into something harder then the drill might start using 600W instead of 500, and then the current draw from the battery would be
600W / 14.4V = 41 amps, and the battery would last less time.
If your battery holds 2 amp-hours and you are drawing 41 amps, then the time it will last is
2 amp-hours / 41 amps = 0.049 hours or about 3 minutes.
If you plugged an 18V battery into your 14.4V drill, assuming it didn't blow up, then when it used 600W it would only draw
600W / 18V = 30 amps, so a 2 AH battery would last
2AH / 30A = 0.15 hours or 4 minutes.
All of these calculations are making a few assumptions about the way your devices behave, and the numbers are probably all wrong (a drill that lasts for 3 minutes? I'd get my money back) but I have done them to try and show how watts, volts, amps and amp-hours relate to each other. A major part of electrical physics is knowing how these quantities relate to each other and how to determine unknowns from knowns.
I end up saying this a lot but a decent physics textbook should clear all this up a lot better than I can. Maybe I'll make an Ible about basic electrical theory.
Can you measure distance in miles per hour? Speed in yards? Height in cubic inches? Temperature in seconds? No- they aren't just the wrong unit, they are the wrong quantity.
Watts are for measuring power- they can be converted to calories per second or BTU per hour or horsepower or soldering irons, but they intrinsically measure energy per unit time. Watt hours are a unit of energy, and can be converted to calories or BTU or electricity meter units or AA batteries or cheeseburgers, but they are a measure of energy.
To convert horsepower into cheeseburgers you have to multiply by a time quantity (seconds, days, time it takes to brush your teeth) to determine how many cheeseburgers your horse has to eat to work for one teeth-brushing.
OK, I'm all out of analogies but I hope that clears up the difference between energy and power. You measure a drill in horsepower and a battery in cheeseburgers.
"but it still seems silly.
Communicating in a non-ambiguous way in a scientific context is silly? The Mars lander crashed because there was a confusion between inches and centimetres, and those are both measures of distance. Mixing up watts and watt-hours isn't just confusing, it's meaningless.
It may seem confusing because the SI convention maintains the names of a lot of the units (hence my use of horses and cheeseburgers rather than watts and watt-hours) but the two are fundamentally different things. Personally I find turning BTUs into the number of cubic yards of salt water you can heat by one fahrenheit more confusing than one watt for one second being one watt-second, but to each their own.
Sorry if it seems like I'm picking on you, I'm really just venting my frustration at people using the wrong quantity to make nonsensical statements. It bugs me every time I hear pressure stated in "pounds"- I know they mean pounds per square inch but that's not what they say, and this bizarre habit of measuring temperature in cubic kilograms or whatever they insist on doing can only lead to confusion.
The statement "this wind turbine produces enough energy in a year to power 2,000 homes" should set your teeth on edge- power 2,000 homes for how long? If you mean a year then the time quantity is irrelevant, if you don't mean a year the statement is meaningless.
