loading
Picture of Buzzbee Tek Six Mod
Recently, I found two Buzzbee Tek Six blasters at a yard sale for $1 each. They had several key points that made them good blasters:
1. They were easy to load
2. They were small
3. They were cheep
4. They looked easy to mod
5. They didn't have half bad power
6. They had gigantic air restrictors (AR), so they would fire even better without them.
I will show you how to do an easy mod to remove the AR and make the blaster fire better.
Step 1: Open it
Picture of Open it
Opening the Tek Six is quite easy.
First, undo all the screws on the cocking mechanism and remove it from the blaster. Then loosen all the rest of the screws and slowly remove the cover. This blaster is stuck together pretty well so you might need to apply some force to open it.
jbaker223 years ago
Are you showing that the valve that allows air pressure out of the barrel when the bullet is in the back of the barrel is bad? It is 3 tiny buttons.
Plo Koon3 years ago
ive had one of these for years and its a VERY reliable gun.
Doesn't work.
Tried this method on two of the barrels and then gave up, deciding to save what was left of the gun.
I'm good with tools, but this method is very sloppy and imprecise and tends to destroy the critical tube behind the air restrictors. That is, it rendered both barrels useless.
