Supercharged Remote Control Battery Hack
 by DualPhase
This instructables shows how to convert your remote control car to use one rechargable and long lasting battery. This less expensive retail store bought model uses 6 AA batteries that require constant replacement. This instructable can be applied to any remote control car the only variation being the voltage, addressed in another step.
Step 1: Disassemble
Disassemble vehicle and expose control board or internal battery terminals.  The main internal battery terminals are below the circuit board on the back of the battery holder.
Step 3: Reassemble and Choose Battery
Reassemble body and drill hole for battery wires.  Solder battery connector that matches the connection type of the new battery.
Rechargeable batteries vary in voltage, current, type and size.
This particular RC truck used 6 AA batteries which means that they control board has voltage regulation and circuitry engineered for 9V.  The servo and motors are also designed for 9V.  AA batteries are 1.5V.  1.5V x 6 = 9V.  A 8V NiMH was chosen for this application.
Step 4: Attach Body
Secure the battery and reattach the body.
makya says: Aug 8, 2012. 3:13 PM
another part to remember is the rechargeable packs are 1.2 volts each battery vs. alkaline which are 1.5 volts each. so 6 AA alkalines are 9.0 volts, and 8 NiCd or NiMh rechargeables are 9.6 volts.
we use the 9.6 volt packs wired in parallel with the AA's in the battery tray and get about a 45 minute run time with the rock crawler like the one pictured.
Matrix-technician says: Feb 20, 2012. 8:04 PM
Is that the rock crawler truck available at wal-mart? I forget the brand. Maybe nikko?
hjklkjh in reply to Matrix-technicianJul 6, 2012. 8:07 AM
yehh the brand is maisto
RCdriver says: Jun 4, 2012. 3:40 AM
I basically did this same thing on the same type of RC, a maisto rock crawler. However, I used a rechargeable 9.6v nicd battery to power mine. that thing could powerhouse over almost anything i threw at it. Highly recommend doing this mod for the maisto rock crawler. (Or most other toy grade rc cars that take AA's)
hi9792 says: Oct 30, 2011. 10:04 PM
your rechargable battery must be the same voltage as the combined battery power otherwise your control board or your motor which was not designed to handle the much voltage will burn out although a hot fix if you want to be a friend i don't recomend it otherwise you could add a boost mode
DualPhase (author) in reply to hi9792Dec 18, 2011. 10:54 AM
This is kind of what I was thinking. This particular RC truck used 6 AA batteries which means that they control board has voltage regulation and circuitry engineered for 9V. The servo and motors are also designed for 9V. AA batteries are 1.5V. 1.5V x 6 = 9V. A 8V NiMH was chosen for this application.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
