Introduction: Solar Plane
Introduction:
This instructable will show you how to create a solar powered plane. This project was done at Newman Smith High School (Carrollton-Farmers Branch Independent School District [CFBISD]) in Carrollton, Texas and was sponsored by the Texas A&M University Society of Flight Test Engineers. We received most of the needed parts from Texas A&M University and built the plane for the High School Solar Plane Competition on May 25, 2013. The project is not for the beginner as it gets a bit complicated. Skills that you will need include soldering skills, plane building skills, monokoting skills, and general R/C plane knowledge. Our team ended up with the Most Creative award and 2nd place in Endurance.
Special Thanks to Texas A&M University, Newman Smith High School Teachers and Principal & the DIY Drones Community (http://diydrones.com/forum/topics/solar-powered-plane).
Below are some pictures of the completed project. The next step will be the list of materials needed.
Also included below is the link for build basics and aircraft aerodynamics- there are two PowerPoints included by Texas A&M University. If you are going to do the project, printing out these two PowerPoints will help you immensely. However, please take note that all the cells must be in series, not in parallel as one of the PowerPoint presentations describes.
https://drive.google.com/folderview?id=0B_bYmGJ0v1Ncb283TF8tWXF6ZWc&usp=sharing
Want to see more photos? PM me and I'll give you a link.
UPDATE: 03/31/2014: Research Paper now included.
Step 1: Materials
Glider (we used the Gentle Lady)
Monokote (We ended up using about 3 rolls- two for the 8 foot wing [bottom] & body of the plane and another clear roll for the panels)
3x6 Solar Panels
Tabbing Wire
Bus Wire
Normal Wire
Micro Servos
Push Rods
Nylon Control Horns
Propeller
Li-Po Battery
ESC (Electronic Speed Controller)
Charger
Connectors (for Wires)
Receiver
Propeller
Electric Motor
CA Glue
Heat Shrink Tubing
Sewing String
Pairing Connector (depends on your transmitter/receiver)
Nuts (for balancing wing)
Balsa Wood Sheets (optional- depends on how big your wing is)
Tools:
Soldering Iron
Flux
Solder
Hobby Knife and extra blades
Heat Gun
Sealing Iron
Large Table
Sand Paper
Drill
Wire Cutter
Digital Multi-Meter
First Aid Kit
Step 2: Building the Wing
To extend our wing, we cut out extra ribs from some balsas wood and duplicated the middle of the wing to extend it.
Follow the plans provided with your kit and build the wing. Extend the wing from the center if necessary.
Step 3: Solar Panels
These solar panels were about as fragile as anything we had ever handled before. Rigid and inflexible, we broke about half of them.
Handling them with the uttermost care is very important to avoid damage to them. Some cracks are okay, it just depends on where they are located and how they broke. Searching up how solar panels work, how to cut them, and how to tab them really helps.
Some background information: The shiny blue side of the panel is negative. The bottom grey side is positive. To connect in series, connect the top tabbing wire to the bottom tabbing wire. There is more information in the PowerPoint.
After tabbing the cells, CA glue them onto the wing in-between the ribs. After doing so, then connect them in series carefully with the soldering iron, making sure to not hurt yourself.
The bus wires go at the end of the panels and are connected to a wire that leads to the middle of the wing from either side.
Step 4: Fuselage, Monokote & Electronics
The construction of the fuselage is not very difficult. Follow the instructions on the airplane plan provided. Wiring on the other hand may be more difficult. If you extend the wing, the CG on the plane may shift and you might have to do some minor modifications on servo placement. Heat shrink all electrical components to avoid any short circuits.
Monokote
Monokoting is not hard either. Use youtube videos to learn how to do it. Make sure when you are monokoting the wing, do the bottom first and then the top and make sure you curve the monotkote over to maintain a good airfoil and reduce any drag. You want to have as much laminar flow as possible. Make sure to use clear monokote for the top of the wing so the solar panels can charge. Cut and Iron the monokote on the wing, then blow it with the heat gun so it contracts and creates a tight wrap around the skeleton of the wing.
Wiring & Electronics
Follow the PowerPoints provided and you should be fine. Put the Nylon control horns where they belong and wrap them in tape so they don't fall off in flight.
Step 5: Testing Electronic Parts
To test the other parts, pair the receiver and the transmitter together. Depending on which brand on transmitter you use, you may need a pairing plug.
Step 6: Test Flying
Step 7: Conclusion
We ended up with 2nd in endurance because the charger wouldn't charge below 12 volts and competition day was an overcast day. But having the cells between the ribs gave us creativity points and using duct tape gave the judges a bit of a kick. We ended up with the most creative award and we're proud. From doing this project, you will learn so much about planes, solar energy, teamwork. It is a great way to spend a couple of weeks on a cool project.
Make sure that if you're interested in green technology and solar planes in general, check out the Swiss project Solar Impulse. Our team got to chat with them when they came to Dallas because of our involvement in a similar project. : http://www.solarimpulse.com/
This dude in Finland is also worth checking out. Here's his Facebook link: https://www.facebook.com/SolarDrone
Steps from here: To move beyond what we've created for now, we can add an auto-pilot system, cameras, and other equipment to make it a semi-autonomous drone. Light sensors can be added on either side of the wing and the plane can circle up the sky with maximum sun exposure on the panels; then at night, it can loiter around, slowly circling back down to Earth. This plan however, would require a new plane, a new design, and a lot of effort, but that is what we intend on doing next year. Heck, we could even connect the plane to a cell tower as one commenter below suggested. The GPS system would then tell people in the vicinity of the plane that the plane is there and the plane could fly over on top, giving the people a live bird's eye view of themselves. Awesome plan, right? The only part getting the technology down is acquiring FAA approval to do such a project.
