IR Remote Control Home Appliances
37,157
69
17
Posted
Introduction: IR Remote Control Home Appliances
Switch ON/OFF any home appliances with the help of IR Remote. Upto 16A depending upon Relay ratings.
Step 1: Parts Required
3way Terminal block x 3
Schrack SPDT 16A 24VDC Relay x 3
1N4148 Diode x 3
BC547 Transistor x 3
3way Berg strip x 1
10KOhms Resistor x 5
470Ohms Resistor x 5
5mm LED x 3
3mm LED x 1
TSOP 1738 x 1
LM7805 IC x 1 (+ its filter parts - 470microfarad 50V electrolytic capacitor, 10nanofarad ceramic capacitor x 2, heatsink if necessary)
LM7824 IC x 1 (+ its filter parts - 2200microfarad 50V electrolytic capacitor, 330nanofarad ceramic capacitor, 100nanofarad ceramic capacitor )
Programmed PIC12F629 IC (Program Included)
8Pin IC Holder
240VAC to 24VDC 1A Adaptor + its female
A strip board to accommodate above
A Plastic Box to accommodate above + small screws and nuts
SONY REMOTE
Step 2: Programming IC + Hex File
Important part is to program the IC.
Use pickit2 or pic serial programmer to code the 'kumir.HEX' file into the IC.
Simple step, if you are in doubt here, give it to some electronics project shop and program it.
File Link - https://skydrive.live.com/redir?resid=5CED783880498823!141&authkey=!ABWOY6Cobjm8T1M
Step 3: Breadboarding
Use schematic and breadboard and feel the output.
Here used LM7824 to get 24VDC for steady driving of the relay.
Here used some spare relays and berg strip replaced by a push switch for testing in breadboard.
Step 4: Stripboarding
This is totally of soldering skills and the layout is of own taste.
Find the pictures.
Insert jumper and configure for any 3 button on any SONY REMOTE.
3 buttons will be stored in the IC, use it for switching the appliance.
Remove the jumper and use the appliance.
Step 5: 240VAC Circuiting
In order to function in both relay and switch, replace normal SPST switch to SPDT i.e Two way switch, for the appliance.
so when 24V adaptor is switched off the appliance will toggle ON of OFF, so that case it can also be operated by SPDT switch.
-Kumaran
kua201@gmail.com
2 People Made This Project!
  • Science of Cooking
    Science of Cooking
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
12 Comments
Sir is there any problem with replacing pic12f629 with 675
It should work, do compare the datasheets.
Post if you have any issues.
Can I upload program with the help of Arduino into PIC12F629 IC
Try your luck....will let you know once if I try too. Works fine with pickit2
These circuit diagrams are not help full for me can u send me another diagram please ??
Dear kumir
I havw made this project but its not working
When i insert jumper so 7 ni led is gone lit and 3 mm led starts blinking.
Can you help me out that where is fault
Hi, I'm doing a kind of similar project, but I'm using Bluetooth and my circuitry is different. But you are putting a 24 volt regulator in series with the rest of your board while your power supply outputs 24 volts. A regulator always has a certain dropout voltage, that's the voltage it will consume for it self, independent of the power supply. You won't get a steady 24 volt out of the regulator if you measure it, but probably something like 22 volt (not that your relays care, they have a certain margin of a couple of volts). But I suggest you remove the 24 volt regulator, because it doesn't improve your power supplies stability or anything.
The rest looks good ;)
Thom
Yes will do that, and do share you bluetooth coding and schematic if you feel so. Thanks
Yeah, I made it a quite some time ago, in my early days of programming. The program is not rocket science, but if you PM me with your email I'll mail the code to you. Back then I didn't make schematics of things, so I don't have the schematic of it, but it was something like: a BJT transistor being driven by the Arduino, and the transistor was switching the low side of the relay coil, other side of the coil was tied to 12V (12V relay). If you have a problem, just message me, I'm studying Electronics Engineering, so I'll probably be able to help ;)
Thom
