Receive SmS IF "GaS" Leakage
Published
Introduction: Receive SmS IF "GaS" Leakage
About: I make hobbyist stuffs and play with electronics follow me to know more https://www.facebook.com/arduinolabviewsolidworks https://twitter.com/learnrobotix
Are you worried about your Home Safety??
This might be a perfect Project to get started with :)
This ible will explain how to receive sms when there is "GAS" Leakage at your home.
This project involves few components you don't need to be a nerd to make it.
List of components:
1) MQ-2 Gas Sensor
2)GSM Module
3) Arduino
4) Connecting Wires.
Step 1: Circuit Connection
You don't need to connect the way I did here, It just a explanation about which pin of arduino meets the GSM pin, all you have to do is place the GSM shield in the Arduino.
Connect the MQ-2 Gas sensor's Digital Outpin to the 7th pin of arduino or any other pin you'd like, but don't forget to change in the program (if you change the pin)
Step 2: Arduino Program
int PIN = 7;
int sensor = 0;
void setup() {
pinMode (PIN,INPUT);
Serial.begin(9600);
delay(5000); }
void loop() {
sensor = digitalRead (PIN);
if (sensor == HIGH){
Serial.println("AT");
delay(1000);
Serial.println("AT+CMGF=1");
delay(1000);
Serial.println("AT+CMGS=\"+919962*****\""); //CHANGE TO DESTINATION NUMBER
delay(1000);
Serial.print("Gas Leakage at HOME (attention required)");
Serial.write(26);
delay(300000); }
You can also download the program from this link: https://www.dropbox.com/s/q4vlcadygyn7giq/gsm_testing.ino?dl=0
Step 3: Add-on to the Project
You can also add a Flame sensor and other sensors to this project and modify the code for your Complete safe guard of your Home.
You can also check My other works in my blog: http://www.labviewarduino.in/
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    7 Comments
    Please.. Ans me as soon as you can... I have very short duration:-(
    Can you give me the code to use both flame sensor and MQ2 gas sensor with this.
    Hello, does it works with SIM 800L also?? Thank you
    Do you have code for SIM300
    or will the same code works with SIM 300 GSM module?
