3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Simple Micro Toothpick Gliders!
H'okay, so, this is my first instructable, it's for making cute little gliders that are fun to make and fly. Making gliders out of toothpicks has always seemed so perfectly scaled and fun to me, and I personally just free-hand the entire thing and have no plans or designs, only ideas. Since this may be hard for some, I'll give you instructions on making one of my simplest gliders. It requires a toothpick(or about the same sized piece of wood, balsa etc. Heck, use whatever scale you want), some thickish paper(construction paper generally works, but the thicker it is the stronger, but also heavier. If you have someplace where the plane is unlikely to be damaged, you could use thinner paper, but I, in my crowded dangerous house, use 28 lb white printing paper which is probably heavier then required to survive a bad landing), and super glue(gel or not, I prefer gel just because it doesn't soak in as much), and something to attach to the nose for balance(I use polymer clay, but pieces of toothpick glued on work just as fine). Tools you need are scissors and maaaybe needle nosed pliers for a more advanced models. Also, there are a few I have made, the orange one is closest to the one we'll be making(see last step for more of my creations). Oh yes, and excuse the dirty fingers, they're the result of working with super glue often. Now, lets get started!
If you just want to look at some cool airplanes, see the last step(But building them is easy so I'd suggest that)
*** Thanks too: http://www.centennialofflight.gov/toothpick/build.htm and http://www.flyingflea.org/Toothpick/ToothpickHM8HM14.pdf for lots of inspiration in basic design and structure, but NONE of my models are directly copied from either source ***
Step 1Begining construction
So, to start, select a relatively straight/strong toothpick, shape of the toothpick doesn't really matter, This will be your frame. Now, take your paper, and cut a simple rectangle out of it, then fold the rectangle in half the long way and trim until it's perfect. Unfold until it's a little less than 90 degrees, then glue the crease to the toothpick like the picture shows, about 1/3rd down from the front of your toothpick(front for me is the thicker end, but if you don't have thicker ends any end you pick will work). This angle is the frame that will hold your wings on, so keep it relatively folded.
65 comments
1-40 of 65next »
Apr 19, 2012. 1:21 PMI luv Duct Tape says:
great instructable! i made the one on the 10th pic with blue tooth picks and blue post-it note paper. i used a slice of hot glue stick for the weight. thanks for all the great ideas! im gonna make a biplane next
Jan 26, 2010. 5:35 PMsuperhornt says:
cambered wings help an airplane or glider fly better because its shape makes more lift than a normal flat wing. in theory, you could have a plane with no camber and a plane with camber with the same weight and design, the plane with cambered wings can have shorter/smaller wings and still fly the same distance because of the extra lift the camber makes. you should try it sometime. also, if you bend down the back(trailing)edge of the wing near the body, you might be able to get even more lift
Jan 19, 2012. 9:31 AMMike McGill says:
It's unlikely that camber will make any difference at these sizes. Camber only starts to come into its own for wings of 3 inches or greater chord, and then not with flat plate wings. You need to have built up wings with some thickness, but of course that would be impractical for these little models, which incidentally I think are great.
Nov 2, 2010. 12:08 PMFrozenIce says:
ok we get it!
Dec 24, 2011. 6:27 AMairgunguy123 says:
how far do they fly.
Dec 9, 2011. 5:23 AMwang1 says:
MAKE A TUTORIAL ON THE RED ONE PLS
CAN YOU MAKE THE RED COLORED ONE???????
Jun 30, 2011. 8:06 AMdombeef says:
You should really make the steps for all of those tiny planes!
Oct 14, 2010. 10:08 AMFrozenIce says:
do you think you can make it with a rubber band powered propeller? im working on one now
Nov 2, 2010. 11:58 AMFrozenIce says:
:( FAILED:(
Mar 7, 2010. 2:02 PMcerealkiller76 says:
Check out this site for cool plans ! :
http://www.geocities.jp/micropaperplane/index2plan.htm
don't be afraid, it's in chinese...;)
Oct 12, 2010. 7:42 AMbalodabazar says:
It's in Japanese.......
Jul 17, 2010. 7:59 AMabsolute zero says:
yea this replys a bit late, but any idea how one might add a prop like in the ones from that site? no idea how they are mounting it to the plane
Oct 9, 2010. 11:04 PMprudhvi95 says:
can u tell me the steps and materials for helicopter that u had done.please send it my e-mail vpr123456789@yahoo.com
Sep 30, 2010. 10:46 AMFrozenIce says:
A maze ing that is sooooooo coooooool you are like the best mini toothpick plane maker i have ever seeeeeeen
THANKS soooooooooooooooooooo much
Mar 6, 2010. 5:10 PMwiidaniel0 says:
(removed by author or community request)
Sep 25, 2010. 5:29 AMwiidaniel0 says:
yeah thx
May 28, 2010. 10:59 PMvpr123456789 says:
how had u made that helicopter i feel difficulty in making it .please send the instructions required for making it .my instructable id:vpr123456789
May 17, 2010. 11:31 AMGuitarmanandy says:
Pls ay how to make the heli copter, can u do it wiv a motor??????????????
pls put another instructable on explaining
Apr 9, 2010. 5:46 PMhumanbat says:
What kind of paper do you use? Do you just use printer paper or cardstock?
Mar 5, 2010. 7:12 PMinstruct39 says:
These planes r so cool. I had an idea seeing a holdable fireball instructable. If i use a match instead of a toothpick i could light the match and have a flaming plane. this way the flame would go backword and light the plane on fire! oh yeah!
http://www.instructables.com/id/Fireballs_you_can_Hold_in_Your_Hands/step8/Light-er-Up/
Feb 26, 2010. 8:51 AMRippingtax says:
 How exactly does the Auto-gyro plane work? It looks like the prop on the top of it would just make the whole plane stall and crash!
BTW Im making your heli now :D
Feb 18, 2010. 6:20 PMcoolio5509 says:
THIS IS THE BEST INSTRUCTABLE I HAVE EVER SEEN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 2, 2010. 5:20 AMrohanbansal says:
Cant  you  make  it  any  BIGGER. STUPID PLANE
Jan 30, 2010. 7:17 PMNatureBoom21 says:
the helicopter looks hella sick! :D
Jan 26, 2010. 5:18 PMsuperhornt says:
usually, you want the centre of gravity(balancing point, or in this case weight) to be about 2/3 of the way back from the leading edge of the wing
Jan 16, 2010. 7:50 PMjester_5123 says:
bout the wing struts, you could just make four "V" shapes instead of two, like you said, attach them between the wings like"AV" on both sides. it seems to me that that would be more strong.idk, now that i think about it, weight would prolly get to be a prob. wit that design.
Dec 29, 2009. 1:24 PMLEDgonuts says:
hi um...well to me the helicopter is pretty esay and to tell the truth im a pro on enginering the planes like how they fly.
Oct 4, 2009. 1:21 PMswimmer95 says:
I want instructions for the helicopter
May 7, 2009. 8:34 AMabishek200096 says:
I am done with all the designs are they flew too but how can I make the helicopter.....Sorry for the video and pictures.
Sep 9, 2009. 12:04 PMchi chi chippy says:
ya i want to know too
Jul 20, 2009. 7:01 PMBlake380 says:
I tried experimenting with this a little bit, and noticed that you can use part of a paper clip instead of a toothpick to make this. Just make sure to cut an amount just as long as the toothpick, and use the smaller types of paper clips, not the larger ones.
Mar 20, 2009. 8:27 PMcowscankill says:
Very cool planes! Now I wish I had superglue....
Jun 26, 2009. 11:27 AMSneaky Chopsticks says:
I made my tip using tape, it's a lot easier for me.
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:crankflip
