Step 3Tail Fins
iImage Information
Now that you have wings, you need a tail. My favorite tail design is fairly simple, and I'd say works better then normal ones, also looks better. To start, cut out a rudder,(or vertical fin), shaped like the first picture. Make sure the top flat area is aimed downward slightly, this will keep your plane from diving straight down. Once you have that, glue it to the back end of the frame, and pay attention to if it's straight forward and vertical, you can check this by looking strait down the plane and comparing with the wings. Now, once that's dry, cut out your elevator just like you did the wings, only about half size. This goes on top of the rudder piece, like in the pictures once again. Do the rear-sight check again. Now it looks like a plane!
