Intruder Detection Calling System
7,979
182
23
Published
Introduction: Intruder Detection Calling System
About: Cool Guy!!
INTRODUCTION
I have made a simple device called "Intruder Detection Calling System" using arduino. This device sends a call on the telephone number feeded in the code, whenever it senses any movement. It is a portable device which can be easily installed on the main gate of the house. It is useful when the residents have gone out and the house is empty. In such a scenario, if somebody tries to break in, my device can sense movement and alert the owner by sending a call on his mobile phone.
Step 1: Material Required
  1. Arduino uno / nano - I have used arduino nano in my device but it should work perfectly with arduino uno as well.
  2. A bread-board for mounting arduino nano
  3. PIR sensor
  4. SIM900 GSM/GPRS MODEM W/RS232
  5. A SIM card
  6. Some male to female wires
  7. A 9 Volt battery
  8. 9V battery cap with DC barrel
I bought all these materials from Makerskart.
Step 2:
The number of the SIM card that you'll be using in the device should be saved in the contact list of the house owner. It can be saved as " Somebody's trying to break in" or "Alert!!" or whatever the owner feels like.
Step 3: Assembling the Device
Connecting SIM900 GSM/GPRS MODEM W/RS232 with Arduino
SIM900 GSM/GPRS MODEM W/RS232 -- Arduino
RX -- D10
TX -- D9
GND -- GND
Connecting PIR Sensor with Arduino
PIR Sensor -- Arduino
VCC -- 5 V
OUT -- D5
GND -- GND
Step 4:
  • After the wiring is complete, insert the SIM card in SIM900 GSM/GPRS MODEM W/RS232.
  • Power the SIM900 GSM/GPRS MODEM W/RS232 with the help of the 9V battery.
  • Once powered, the green LED on the MODEM blinks repeatedly. However, when the MODEM detects a mobile network, the green LED on it blinks once in every 3 seconds. Now, the MODEM is ready for use.
  • Next, power the arduino.
Step 5: Uploading the File
Once everything is ready, open your arduino IDE, choose the correct board, processor (if required), port and upload the file which has been attached.
Step 6: Intruder Detection Calling System - Functioning Successfully
  • Casting Contest
    Casting Contest
  • Make it Move Contest
  • Microcontroller Contest
23 Comments
I made the circuit but it is not sensing ....I've also tested each component individually also
Check the final wiring and code! That's all I can say!!
in your code you have only 10xs representing 10digita, how about countries with 11 digits?
I don't even know if this gsm shield would work in that country!?! I don't have idea about this
I think it should work for atleast 4-6 hours!?!
I noticed that the RS 232 was not used, was there a reason for selecting this board with this feature? Btw, loved your ible!
No, there was no specific reason. It was just that this board was easily available for me, and so I used it.
Thanks for the remark!!?
The difference between your shield and my shield is that your shield is smaller in size, has Bluetooth and most probably has a different operating voltage. So I think it should work fine with with the same wiring and code. But since I have not used it yet, I won't be able to guide you on how to use your shield!
Thanks for the reply. I am having questions about how to properly connect a GSM shield to an Arduino and have the RX and TX pins and #defines set up properly. It is clear using jumpers from board to shield, but not so clear when installed as a shield. Suggestions? Thanks
You want to know the connections of sim900 shield or sim800?
I am having questions about how to properly connect ANY GSM shield to an Arduino and have the RX and TX pins and #defines set up properly. It is clear using jumpers from board to shield, but not so clear when installed as a shield. Suggestions? Thanks
Well, I think that different shields would require different wiring. I also don't know about the pinout of all shields.
Yes, Arduino Uno also works perfectly with the same wiring and code!
interessante
Where is your code? I do not see it attached to your lble.
You can only open it after downloading, if you have the Arduino IDE. I'm still posting it here-
#include <SoftwareSerial.h>
SoftwareSerial mySerial(9, 10);
int inputPin = 5; // choose the input pin (for PIR sensor)
int val = 0; // variable for reading the pin status
void setup() {
pinMode(inputPin, INPUT); // declare sensor as input
Serial.begin(9600);
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
mySerial.begin(9600); // set the data rate for the SoftwareSerial port
delay(2000); // necessary delay
mySerial.println("ATDxxxxxxxxxx;"); // just replace the 10 x's with the number you want to send the alert to (eg-house owner). DONT MAKE ANY OTHER CHANGES!!
else {
//Nothing to be done here
delay(2000); // Check for motion after 2 seconds
It is in step 5. You have to download it first to read it.
