Inverse Peanut Butter Cup Pie by shesparticular
Contest WinnerFeatured
In celebration of Pi Day, why not make a yummy treat that incorporates another mathematical favorite - inverse numbers.1
Standard peanut butter cups combine a chocolate exterior with creamy peanut butter insides, and they're fantastic. Though it may be hard to believe, when swapped to produce a peanut buttery crust filled with creamy chocolate filling, they're even more delicious.
1Geek note: The multiplicative inverse of a number (x), also called the reciprocal, is defined as 1/x or x-1
Step 1: You'll Need. . .
Software
For the Crust (amounts can be doubled if desired - this makes approximately 6 mini-pies or one 10 inch tart/pie):
  • 1/2 cup all-purpose flour
  • 1/2 teaspoon baking soda
  • pinch of salt (approximately 1/16 teaspoon)
  • 1/4 cup packed brown sugar
  • 2 tablespoons sugar
  • 4 tablespoons (or 1/4 cup or 1/2 stick) butter
  • 1/2 cup smooth peanut butter, at room temperature
  • 1/2 large egg (beat the egg, then measure out half of it)
  • 1/4 teaspoon pure vanilla extract
For the Filling (you may end up with some extra, but I for one don't mind extra chocolate pudding):
  • 1/8 cup cornstarch
  • 1/4 cup sugar
  • 1/16 teaspoon salt (a large pinch)
  • 1/4 cup milk (2% or whole)
  • 1 cup heavy cream
  • 3 ounces semisweet or dark chocolate, coarsely chopped
  • 1/2 teaspoon pure vanilla extract
Optional Garnish:
Hardware
For the Crust:
  • large mixing bowl and wooden spoon or hand mixer (food processor can also be used)
  • measuring cups and spoons
  • small tart/pie pans (removable bottoms are strongly suggested) (this is the pan used here) - you can also make a larger pie if desired (crust should be enough for a 10 inch tart/pie pan - one with a removable bottom is suggested)
  • plastic wrap
  • dried beans or pie weights (optional)
  • shot glass or spoon to press dough into pan (optional but suggested)
For the Filling:
  • heavy-bottomed sauce pot
  • silicone spatula
  • whisk (optional - needed if your pudding gets lumpy)
  • fine mesh strainer (optional, also to prevent lumps)
chicopluma says: Mar 26, 2011. 8:05 PM
looking at it makes me hungry
shesparticular (author) says: Mar 26, 2011. 8:07 PM
Thanks so much - you should try them out!
nak says: Mar 24, 2011. 4:41 PM
Dis looks yum yums
shesparticular (author) says: Mar 24, 2011. 4:56 PM
Thanks so much!
ShadowJesus says: Mar 24, 2011. 12:43 PM
Oh man. This looks amazing.
And easy!
Thanks!
shesparticular (author) says: Mar 24, 2011. 12:46 PM
They take a little prep-work, but after that are really simple (and delicious!). Thanks so much for the comment!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
