Introduction: Inverted Fishtail Rainbow Loom Bracelet
Picture of Inverted Fishtail Rainbow Loom Bracelet
Step 1: Supplies
Picture of Supplies
- Loom
- Rubber Bands
- Hook
- C- or S- Clips (not pictured)
Step 2: Set Up Like You Are Making a Normal Fishtail Bracelet
Picture of Set Up Like You Are Making a Normal Fishtail Bracelet
Put a rubber band twisted into an 8 shape and put on two pegs. Then place two more rubber bands on normally, like in the photo.
Step 3: Take the Bottom Band And...
Picture of Take the Bottom Band And...
Step 4: Pull It on Top.
Picture of Pull It on Top.
Step 5: Do the Same for the Other Side
Picture of Do the Same for the Other Side
Step 6: Place Another Rubber Band on Top
Picture of Place Another Rubber Band on Top
Step 7: Instead of Directing Picking Up the Bottom Band, You Pull Back the Middle Band With Your Hook
Picture of Instead of Directing Picking Up the Bottom Band, You Pull Back the Middle Band With Your Hook
Step 8: You Then Grab the Bottom Band With Your Hook
Picture of You Then Grab the Bottom Band With Your Hook
Step 9: Then You Pull That Band Over on Top. Repeat on the Other Side.
Picture of Then You Pull That Band Over on Top. Repeat on the Other Side.
Step 10: Continue the Same Steps
Picture of Continue the Same Steps
All you do is just keep adding bands on top then pulling the bottom band through the middle band. That's it! You can gently pull the bottom band like in the picture after you pull each band up and you will start to see the pattern. Continue until your desired length.
Step 11: When You Are Done
Picture of When You Are Done
When you reach the length you want, don't put any more bands on. You just want the two bands like in the photo.
Step 12: Take the Bottom Bands And...
Picture of Take the Bottom Bands And...
Step 13: Pull Them on Top of the Other Band
Picture of Pull Them on Top of the Other Band
Step 14: You Can Put Your Bracelet on Your Hook Like in the Picture So It Is Easier to Put on Your Clip
Picture of You Can Put Your Bracelet on Your Hook Like in the Picture So It Is Easier to Put on Your Clip
Step 15: To Finish, Put the Ends Together With a Clip
Picture of To Finish, Put the Ends Together With a Clip
Step 16: Enjoy Your Bracelet!
Picture of Enjoy Your Bracelet!
Leiana2213 (author)2014-05-04
Oooo, Im trying this now cuz I got bored of the fishtail
_be_back_soon (author)2014-01-24
Same I really liked urs and wasn't confusing like the other ones. Good job!
kawaiilover (author)2014-01-19
Honestly, I've seen many if these on instructables. But your tutorial is by far one if the best I've seen! Way to go, love em! :)
About This Instructable
78,794views
15favorites
License:
More by rayray9889:Garlic Chicken PizzaRoasted ChickpeasFunfetti Mug Cake
Add instructable to:
