3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Inverted Tomato Planter
  • last photo ←
I've been making these for the past couple years and people often ask me how I do it. Today I decided to document my method for creating these wonderful, space-saving planters that let you grow delicious tomatoes in the tiniest of spaces.
The design is simple: it's basically a hanging planter with a hole cut into the bottom and a tomato plant pushed through the hole. On the top of the planter you can put anything you want: flowers, herbs, or other small plants. I'm using oregano, because it can be easily grown in a pot this size, and it makes a wonderful seasoning for the tomatoes in a fresh garden salad.
The tomatoes I'm using are a variety called "Supersweet 100". I've grown these for the past few years and they are just delicious -- sweet & tart with a crisp bite. They aren't very big, about the diameter of a penny, but that's fine for our purposes. Smaller tomatoes do better in these planters than larger ones, which require more soil and space. Also, larger tomatoes tend to sag towards the ground, which puts stresses on the stem of the plant.
Properly watered and cared for, a planter like this can yield a great harvest. Last year I picked over 150 tomatoes from a single plant! And you can reuse the planter year after year!
Regarding planting time, you should follow the instructions that come with the plant, usually located on the back of the little plastic tag that indicates the variety. The nice thing about these planters, however, is that if you start them a little early you can just hang them inside until it's time to bring them outside.
Step 1What You'll Need
What You\
You will need:
A pair of scissors.
A 10x10" square of peat paper (also known as mulch paper). If you don't have peat paper, or don't want to buy a 50' roll of the stuff for just this little project, you can use a paper coffee filter (even a used one will work if you dry it out).
A knife or wire clippers to cut out the bottom of the plastic planter. I'm using my Leatherman (not shown), because I use it all the time.
A hanging planter with an inverted frustrum at the bottom. This is an important feature, because it traps water and keeps the soil from washing out through the hole.
A tomato plant -- any grape or cherry variety will do. I'm using the 'Supersweet 100" small cherry variety.
An herb plant -- I'm using Golden Oregano, though you could also use basil, thyme, or even small flowers. Any plant with a root system that stays close to the surface will do.
Topsoil -- Choose a good one. I use MiracleGro Organic Choice for my potted plants, though pretty much any enriched quality topsoil will work.
8 comments
May 28, 2011. 11:11 PMElectroFrank says:
I am a beginner, so please excuse my ignorance. Why not just let the tomato plants grow over the sides at the top of the bucket, which would allow several plants in each bucket (obviously on the sunny side) and give a greater length of stem for fruit to grow on ?
But here's a thought anyway: Hang the bucket from a spring balance, (spring scale in the US ?) and this will give an indication of when (and how much), watering is needed.
May 10, 2010. 2:50 PMGreasetattoo says:
GREAT job..
I enjoyed you instructable.
Pictures are great!
Well done....
Apr 10, 2010. 6:50 AMdiannpcw says:
This is the best up-side-downer yet!
Apr 6, 2010. 5:51 PMbeckysews says:
Thank you so much!  I want to try this and you just saved me money and time wasted trying o figure it out myself!
Apr 5, 2010. 8:21 PMjmkaay says:
This is not only a great Instructable, but it is very well written. Thanks!
Apr 5, 2010. 4:47 PMahensnest says:
Love it! I was just thinking today that I'd like to try and make something like this, now I can use up some of my old hanging pots. Thanks!
Apr 4, 2010. 5:52 AMadafruit says:
this is great, nicely done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:johngineer
I like to make things.
