3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Inverted Tomato Planter
Step 2Making the Cut(s)
Making the Cut(s)
You should have a piece of peat paper, about 10x10" square. Enough to cover the entire bottom of the pot. If you want to cut it into a circle, you can do that too.
Cut into the paper from the middle of one side, approximately halfway through, and then at the center cut out a small diamond shaped hole, no bigger than a dime. This is where the tomato plant stem will pass through the paper.
If your planter has a removable bottom base, you should remove it because you won't need it. Save it to use it as a coaster under other potted plants, or have a game of frisbee. :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:johngineer
I like to make things.
