Invisible Book Shelf
Step 2Measure Twice, Cut Once.
Measure the half way point, make a mark, set down your bracket, draw an outline, measure again, cut out a hole deep enough that the bracket will set flush. You are doing this to the back or bottom of the book, the part that will be visible in the finished product.
13 comments
Jan 19, 2012. 11:03 PMor_ford98 says:
use the twilight saga, they're useless :)
Jan 4, 2012. 7:40 AMFelinaFontina says:
Fabulous project, but my favorite author is Stephen King. A better choice would be anything by Rush Limbaugh, but I wouldn't want to look at it every day!
Jan 30, 2007. 6:03 AMVisitor says:
If you use two angle brackets you can leave the upper cover of the book unglued and cut a small secret box inside the book, between the brackets.
Sep 4, 2009. 1:55 PMswolleneyeball says:
Yes and james bond would smile down on you for it. But the idea of a hollow book is to hide something, usally with as little attention as possible, the idea of this thing is to draw attention. Although most ppl would be so amazed at the levitation trick they probly wouldnt pay attention to much else
Feb 3, 2007. 8:51 PMthecosas says:
yeah, but good luck finding studs in your wall that are that close together. I wouldn't trust this thing to drywall alone.
Sep 30, 2009. 2:25 PMCubie2 says:
that's why you put drywall screws in and THEN you put in the regular screws.
Feb 6, 2007. 2:20 AMVisitor says:
I am going to estimate the weight of a single book to 1.5kg. If this shelf is going to hold five books, that makes 7.5kg. Since the center of gravity for the books is about as far from the wall as the fastener is from the corner of the angle iron, the fastener should be able to take 10kg pulling load to make this setup safe. There are special fasteners (or one could as well call them "common fasteners" since they are available in every hardware store) for drywall to which one can safely hang this kind of a load. Search google for "drywall fastener." And keep in mind that when you use two angle brackets, the load to the dry wall is divided evenly to the two fasteners. In this case 5kg pulling load would be enough.
Nov 10, 2009. 3:44 AMbowlerhatman says:
1.5kg is a very...generous...estimate. That's sort or, hardback oxford dictionary weight, roughly speaking. I think it would be uncommon to find multiple books weighing a kilo and a half in a single house. This is just going on my years as a library shelver. I carry somewhere around fifteen books at a time, that's an armload. I'm not hugely strong, and there's no way Icould carry 22.5kg on my left arm.
The rest of your points are 100% valid though. Just thought I'd point out the exaggerated weight estimate.
Mar 8, 2009. 6:04 PMnaruto the ninja13 says:
you cut a book?!?!? =[]
Apr 11, 2009. 10:23 AMbookmark says:
that is sacrilegous. if you burn books than you might be a bit kookoo
Apr 1, 2009. 8:58 PMfordsucks2 says:
You sound like Montag from Fahrenheit 451....lol
Jan 19, 2012. 11:04 PMor_ford98 says:
LOL look at my name
May 9, 2009. 8:07 PMwprejs says:
i love that book read it in 4th grade its amazing wat the world changed to lol
Feb 11, 2009. 8:33 AMLordMekk says:
They make screw fasteners that look like giant corkscrews to hold up cabinets in sheetrock walls. I have used them to hold shelves up in sheetrock walls before. They do okay. You can get them in just about any hardware store.
Jan 21, 2008. 6:17 AMnkk07 says:
wont this ruin a really exspensive book like the one jk wrote and sold about 3-4 of them £2 mil each.
May 25, 2007. 10:31 AMflydesignlab says:
I guess it was easier for me, my walls are solid brick so I stacked a lot of books on it and it was fine. I was more worried about some other part failing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:dorxincandeland
