Invisible Book Shelf
Step 5Glue, and Apply Pressure
The glue will hold the bottom cover of the book in place, and the screws hold the pages together. Put the stack of books on top of the whole deal and wait overnight.
13 comments
Sep 10, 2011. 7:19 PMblinkyblinky says:
How much weight can this hold?
May 4, 2010. 2:52 PMLaBeasy says:
question, would it be more stable if you used two L brackets? maybe i dont know enough about it, but it seems a little bit unstable this way.
Sep 6, 2009. 1:52 PMyeladot says:
I would also screw in the bracket.
Oct 2, 2008. 10:11 AMpcro says:
Any reason you've used only one L-bracket? My instinct would be to use two.
Oct 6, 2008. 7:48 PMsrhadaham says:
thats a pretty big book to span two studs 16 inches standard 24 inches(i think) California
Jul 28, 2008. 10:33 AMsurfreak says:
Krazy Glue FTW!
Jun 23, 2007. 12:32 AMrobzored says:
Could you use epoxy if you're too lazy to find the elmers glue?
Feb 12, 2007. 5:46 PMmahbooty says:
have you tried hot glue? or are you using the glue to soak into the paper more?
Mar 6, 2007. 1:40 PMPandatrap says:
elmers glue is actually pretty strong, it should be fine, and yeah very cheap. I think hot glue has just as much chance of ripping away from the paper
Feb 19, 2007. 3:47 PMMepain says:
yellowbook rocks =)
Feb 3, 2007. 8:52 PMthecosas says:
is the bracket supposed to be screwed in at this point?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:dorxincandeland
