IoT Base Platform With RaspberryPi, WIZ850io : Echoback Application
864
9
Published
Introduction: IoT Base Platform With RaspberryPi, WIZ850io : Echoback Application
About: S/W Engineer for Open Source Platform.
I know RaspberryPi platform for IoT. Recently WIZ850io is announced by WIZnet. So I implemented a RaspberryPi application by Ethernet SW modification because I can handle a source code easily. You can test the echoback application through RaspberryPi and WIZ850io. Please refer to the following step.
Step 1: Prepare Materials
Please refer to the following.
1. RaspberryPi 3 Starter Kit
2. WIZ850io
3. UART2USB adapter
4. LAN cable
5. USB cable
Step 2: Hardware Connection
Please connect an USB, LAN cable, WIZ850io and UART2USB adapter.
You can get more HW info by the following site.
https://pinout.xyz/pinout/spi
http://wizwiki.net/wiki/doku.php?id=products:wiz850io:start
Step 3: Prepare Development Environment
Step 4: Software
Step 5: How to Run : Modification
Step 6: How to Run : Result
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
