IoT Base Platform With RaspberryPi, WIZ850io : Ethernet Module Driver
110
Posted
Introduction: IoT Base Platform With RaspberryPi, WIZ850io : Ethernet Module Driver
I know RaspberryPi platform for IoT. Recently WIZ850io is announced by WIZnet. So I implemented a RaspberryPi application by Ethernet SW modification because I can handle a source code easily. You can test Ethernet Module Driver through RaspberryPi and WIZ850io. Please refer to the following step.
Step 1: Prepare Materials
Please refer to the following.
1. Raspberry Pi 3 Starter Kit
2. WIZ850io
3. UART2USB adapter
4. LAN cable
5. USB cable
Step 2: Hardware Connection
Please connect an USB, LAN cable, WIZ850io and UART2USB adapter.
You can get more HW info by the following site.
https://pinout.xyz/pinout/spi
http://wizwiki.net/wiki/doku.php?id=products:wiz850io:start
Step 3: Prepare Development Environment
Step 4: Software
Linux Kernel : WIZnet Ethernet Module Driver for W5500
https://github.com/borg42/w5x00
Step 5: How to Run : Modification
I modified the source code to fit Raspberry Pi.
Step 6: How to Run : Result
I copied w5x00 module into Raspberry Pi.
  • Remote Control Contest 2017
  • Arduino Contest 2017
  • LED Contest 2017
    LED Contest 2017
Questions & Answers
