IoT Dog Bowl
Published
Introduction: IoT Dog Bowl
About: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths caused by my projects.
Pets are awesome, so I decided to make a IoT dog bowl that can send me texts, push notifications, and post to twitter. It notifies me when either my dog ate his food, his bowl just got refilled or the water tank is empty. Now this isn't just for dogs its for any creature that could use a drink. Without further talk lets start!
Step 1: Parts
you will need:
1x - Ir avoidance sensor (http://adf.ly/1SN5NG)
1x - LinkIt One (http://adf.ly/1SN5gD)
Foil Tape (http://adf.ly/1SN5vJ) - I like this stuff because it sticks incredibly well
1x Fountain Pump (http://adf.ly/1SN6L6) - Dont get a pump over 400gph + you will need some tubing
1x Relay (http://adf.ly/1SN6jh)
1x extension cord (you will need the plugs) (http://adf.ly/1SN73v) this one is nice because you can order a 1ft peice
Some Wires
A dogbowl
1x rgb led (http://adf.ly/1SN7Of)
some skill
Step 2: Build Part 1
Picture 1 - Connect RGB Led
Picture 2 - Connect Sensors
Picture 3 - Connect Relay
Picture 4 + 5 Attach screws to connect to dog bowl
Picture 6 - Stick 2 strips of foil tape to the side
Picture 7 - connect a wire to each strip (because only one side of the tape is conductive i used the tape to hold the wires)
Pictures 8 + 9 + 10 - Screw on your IR sensor until its tight then face it to the food bowl
Picture 11 + 12 - Connect the bucket/tank wires to the tape
Pictures 13 +14 +15+ 16+ 17 If your pump has a adjustable flow rate turn it to the min then put it in your tank and fill the tank up (due to siphoning you might want to put the bowl higher then the tank and add a check valve)
Picture 18 - Duck tape your tubing to the bowl with NON-TOXIC ductape
____________________________________________________________________________________
Coding the linkit one
Visit my site http://adf.ly/1SQY5x for the code
and to set up bynk add the (email, twitter, and push items)
Simple!!
Step 3: Build Part 2
Make your in-line-relay-switch and plug it into a GROUNDED - SURGE-PROTECTED - outlet
here is a schematic for the switch (http://adf.ly/1SNAgI)
have all hands off everything and turn it on (bum-bum-baa)
If it looks good (ex no smoke or sparks) then you should be good to go
Step 4: Test #1
Turn everything on the linkit one should soon connect to blynk and if the bowl is empty start to fill it up.
Step 5: Place It on the Ground and Your Good to Go
I hope to like this project and vote for it also please feel free to share it
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
