IoT Push Notification Using Nodemcu on Phone(For Anything)
Introduction: IoT Push Notification Using Nodemcu on Phone(For Anything)
Sending notification for messages, emails are old fashioned...
So lets make something new that is very easy and simpleNO COMPLICATED SERVER SIDE PHP HOSTING OR OTHER COMPLICATION...
Home automation, water pump level, garden watering, automated pet feeding, PIR alarm and much more whatever you want to get notified on your phones.(android/iOS)
ENJOY and be lazy but get notified!!!!!
Step 1: Components Required
the main component is Nodemcu(ESP8266) or any other equivalent development boards like adafruit huzzah, wemos d1 mini etc.
And the sensors to use depends upon your need...
I'm using the notifier to notify my previously made internet/cloud controlled project, PIR alarm circuit, ultrasonic sensor controlled water level, IR sensor door!!
After the configuration of sensors the vital thing left is programming.
To configure nodemcu in arduino please visit my previous instructables...
NOTE: Please read the whole instructable don't half read it and damage your kits, I will not be responsible :P
Step 2: ESP_Notify and Library
We can find the ESP notify application on google play store or we can get the apk from anywhere esle.
After installing the app we need to
  1. SIGN IN(using google account)
  2. press the SEND TOKENs option
  3. use your email
  4. in email you will get the USER ID, DEVICE ID and Library zip URL
  5. download the zip from the link
Once the library is downloaded you can add it to your Arduino IDE by
  1. clicking on Sketch
  2. Include Library
  3. Add .ZIP Library in the IDE and then selecting the downloaded file from your Download folder.
Step 3: CODING
To know something about the library go for the examples in arduino:
  1. File
  2. Examples
  3. ESP_Notify
  4. send_notification.
To make it work just do change 3 things your WiFi SSID (name), WiFi password and Device_Id.
Device_Id you can get from the email forwarded previous by SEND TOKENS.
So after testing the code we can now tweak it for our use like previously told...
Home automation, PIR alarm, water level alrm, IR door sensor notification
Step 4: Circuit Wise Program
I have used PIR sensor, Ultrasonic sensor, IR sensor for different works as well as in cloud controlled project I have inserted the library and used the "notifier.sendNotification(device_id,"header","message")" in desired places to get notified on my phone on actions.
According to my code I have used pin D0,D1 for Ultrasonic sensor, D2 for PIR, and D3 for IR sensor.
So download the above given code and modify it like you want.
Step 5: ESP Notify App
From the app we are getting the desired notification and its the simplest app I have found for notification with ESP8266. It's not the best but the simplest.
Pros- very easy, simple, reliable
Cons- couldn't find if parameters can be passed till now, may be added afterwards..
Thanks for the application and the easy to use procedure without going in a hectic process of app, event, php on server creation.
So enjoy and support...
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    Good project but app tell me my email address is not usable.
    Sorry but I don't have a clue for that discrepancy of the app. This doesn't happen usually try another gmail account!! that may help :)
    Nice project,but cannot get the app.
    I found the app easily, as normal app
    very pleased to know that... please notify me if you tried this project!! :)
    One question. The Ultrasonic (HC-SR04) has 5V logic on the Trig and or Sensor output. The NodeMCU has a 3V3 logic on the input. Official the NodeMCU is not 5V (input) tolerant. You don't have any trouble? I did a project with NodeMCU and Ultrasonic and I us some resistors the level shift 5V to 3V3. I guess for long term operation it is better.
    I have my cloud controlled nodemcu project installed in my house for more than 2months. And the nodemcu may it be wemos/lolin/amica any model has a logic output of 3V3 but the max input voltage through micro usb or Vin pin can be 12V (max) but not recommended as it doesn't have heat sink with tiny voltage regulator. my power bank used in the project with ultrasonic sensor has output voltage of max 5.1V so no problem with nodemcu as its voltage regulator generate almost no heat. Same power bank but with 2 parallel output was used to power ultrasonic sensor and nodemcu, echo n trig pin can be handled with 3V3 logic. actually air acts the coolant of that negligible heat in nodemcu for 5V. So no problem :)
    awesome project...will it really work if I only include the library and use the function? i need to try this. thanks
