Introduction: IoT Workshop: Prep Work
Picture of IoT Workshop: Prep Work
The labs in this series build on each other to enable you to prototype your own Internet of Things (IoT) devices. In this lab you will use Node.js and an open source framework for interacting with hardware called Johnny-Five, which works as a baseline control kit for Arduino-based projects. This enables you to write applications in JavaScript that can run either on your computer connected to an Arduino board or directly on the board itself (if the board has a Linux distribution, like the Arduino Yun and Linino ONE).
I chose the Arduino Yun for this workshop because it has both a Linux distribution and on-board Wi-Fi, although several of the labs can be completed using any Arduino board because the Node.js code will run on your laptop and use the Arduino over USB. If you want to deploy the applications you build to the Arduino, you will need a board that has a Linux distro (such as the Yun or the Linino ONE).
Step 1: Bill of Materials
To prepare your development environment for this lab series you don't need anything other than a computer. Each lab in the series will have a bill of materials indicating what is required for that lab.
If you want to prepare yourself further before the labs you can acquire the following:
  1. Arduino Yun (1)
  2. USB to micro-USB cable (1)
  3. An Arduino compatible starter kit w/o the board (1)
    1. An example would be the Adafruit ARDX - v1.3 Experimentation Kit for Arduino (Uno R3) - v1.3 (it comes with an Arduino Uno R3, which you can use only in some of the early lessons)
Here is a list of individual sensors and devices you may want to acquire (not all of these will be used in the workshop, but this is a good core kit to have):
  • Premium jumper wires (75)
  • 9V battery clip (1)
  • 5mm diffused RGB LED (1)
  • Piezo Sensor (1)
  • 5mm red LEDs (10)
  • 5mm green LEDs (10)
  • 10mm blue LED (1)
  • Toy DC motor (1)
  • 9g High Sensitive Mini sensor (1)
  • 74HC595 (1)
  • Buzzer (1)
  • 1M resistor (1)
  • Pushbuttons (2)
  • Potentiometer - 10K (1)
  • Light sensor (5528) (1)
  • TMP36 (1)
  • Relay (5v,3A/120VAC) (1)
  • P2N2222A (2)
  • 560 Ohm resistors (25)
  • 2.2k Ohm resistors (3)
  • 10k Ohm resistors (3)
  • 220uf capacitor (1)
  • 1N4001 (2)
  • Breadboard (1)
Step 2: Install the Arduino IDE
While you won't use the Arduino IDE very much in the set of labs, it is necessary for a couple of things. For one thing, installing the Arduino IDE also installs the USB drivers for the Arduino board.
Go to http://www.arduino.cc and follow the links to download the latest version of the Arduino IDE. Make sure that the checkbox for the USB driver is selected during install (it typically is by default).
Step 3: Install a Code Editor
If you don't already have one installed, pick a text/code editor. Feel free to use anything you like, provided it won't inject any extra text into your files.
Some Options
Step 4: Install Git
Picture of Install Git
Some of the tools you will be using in this workshop require Git. The download link can be found here.
Windows Only
During the Git install, check the option to Use Git from the Windows command prompt (see image above).
If you don't choose this option, after you have installed Git, you need to add the path to get to your development environment. To do that, add the path to Git to the PATH environment variable.
Open Control Panel > System and Security > System then click on Advanced Settings.
Click on the Environment Variables button toward the bottom of the dialog.
Locate the User variable named PATH and double-click it.
Append the following to the Variable value textbox (if you installed Git to a different location you will need to modify this value accordingly):
;C:\Program Files (x86)\Git\bin;C:\Program Files (x86)\Git\cmd
Click OK to close the Edit User Variable dialog.
Click OK to close the System Properties dialog.
Close any remaining dialogs/windows (i.e. Control Panel).
Step 5: Install Node.js
In the labs you will write small programs that will run on your computer, connected to your Arduino (these can also be deployed to run solely on your Arduino Yun). These programs will be written in JavaScript and will be built on Node.js. If you are not familiar or experienced with Node.js, don't worry. You will learn everything you need to know for these labs in these labs.
Follow the instructions here to install Node.js on your computer.
Step 6: Install Bower
Bower is a package manager similar to the Node Package Manager (NPM). For these labs we will use both NPM and Bower. You install Bower using NPM.
On Windows, open the Node.js command prompt and type the following:
npm install -g bower
On Mac OS X open Terminal and type the following:
sudo npm install -g bower
Step 7: Install Apache Cordova and Cordova Icon
Apache Cordova
Apache Cordova is an open-source mobile development framework. It allows you to use standard web technologies such as HTML5, CSS3, and JavaScript for cross-platform development, avoiding each mobile platforms' native development language. Applications execute within wrappers targeted to each platform, and rely on standards-compliant API bindings to access each device's sensors, data, and network status.
npm install -g cordova
sudo npm install -g cordova
Cordova Icon
Cordova Icon is a tool that provides automatic icon resizing for Cordova apps.
npm install -g cordova-icon
sudo npm install -g cordova-icon
Step 8: Install Johnny-Five
Johnny-Five is an open source JavaScript framework that provides a simple object model for interacting with an Arduino-based board and the sensors and devices you connect to it.
Once you have Node.js installed, install Johnny-Five by opening a terminal window (Mac OS X) or Node.js command prompt (Windows) and execute the following command:
npm install johnny-five
Step 9: Install Nitrogen
Nitrogen is a messaging service that will act as a gateway for your Thing connecting to Azure. Nitrogen supports connecting devices via Message Queue Telemetry Transport (MQTT) or using the Nitrogen Node.js client library (you can learn more about MQTT here). You install Nitrogen using NPM.
npm install -g nitrogen-cli
sudo npm install -g nitrogen-cli
Step 10: Set Up a Development Directory
The last thing to do is prepare a place to save all of your work in the labs. I recommend an easy to navigate to directory with a relatively short path. Create a new folder/directory for the workshop - I recommend:
Windows
C:\Development\IoTLabs
Mac OS X
~\Devleopment\IoTLabs
That's it for now. You are ready to start the first set of labs.
Once you've completed this lab, be sure to click the "I Made This" button at the top of the page. That helps me know how many people are working on this lab - the more people using the lab, the more lab modules I will create.
Next, go to Lab 1: Digital Output.
josegalarceh made it! (author)2015-08-26
gracias por los pasos!! muy claros todos!
lamiastella made it! (author)2015-06-08
Sure!
Interesting to learn about new technologies to talk to the clouds
I installed #JohnnyFive and did a quick research who else is using it and what for. Sounds very interesting and thanks for introducing it :)
I installed cordova and cordova-icon on OSX.
About This Instructable
2,452views
21favorites
License:
Bio: Director, Strategic Engagements, DX-TED, Microsoft
More by dougseven:IoT WorkshopIoT Workshop: Lab 4 - Sending Data to the CloudIoT Workshop: Lab 3 - Controlling Output with Input
Add instructable to:
