Ion Motor
Published
Introduction: Ion Motor
An ion thruster is a form of electric propulsion used for spacecraft propulsion. It creates thrust by accelerating ions with electricity.(wikipedia). Ion motor is a simple ion thruster.
see also:
https://en.wikipedia.org/wiki/Electrostatic_ion_thruster
http://www.esa.int/Education/Ion_motors
What you need:
- Aluminium foil
- Wire
- Scissor
-Sewing pin
- Cardboard
- PVC pipe (or some holder)
- high-voltage power supply (like TV flyback, Marx generator, Van de Graaff machine, Wimshurst Machine…)
video file
Step 1: Rotor
  • Print pattern
  • Copy patter to aluminium foil
  • Cut rotor
Step 2: Base
  • Cut a 2inch PVC pipe and make a calendar
  • Cut a circle in cardboard (2inch)
  • Make a hole in the center of the circle
  • Make a small pipe with Aluminium foil (like picture)
  • Insert a striped wire to aluminium pipe and punch it, use some tape glue
  • Insert aluminium pipe into a circle and use glue to fix it
  • Glue circle to the base
Step 3: Motor
  • Make a hole in the center of the rotor
  • Insert a sewing pin in the hole
  • Join rotor to the aluminium pie with a sewing pin
  • Connect the wire to the high-voltage probe
  • If the rotor does not rotate, close other high-voltage probe to the rotor
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
    Do you have a video of this working? This looks pretty dangerous.
    yes. you can see from "video file" link
    it is high-voltage and very dangerous
