Static electricity is high voltage (HV) at low current. That unexpected ZAP! occurring when you walk across a carpet and touch a metal object demonstr...
Adjust the movable collar to allow rotor to spin freely when the cage is placed on its side. If the rotor stops in the same position, disassemble it...
Your turbine is almost ready to roll :). Just peel off the label and carefully remove the bottom of the peanut container with a can opener without d...
The following variables will affect your turbine’s performance: (a) electrode-rotor gap, (b) bearing friction, (c) rotor balance and (d) inter-elect...
Consider mounting your project on a wood cigar box with oversized rubber bushings as stand-offs to absorb turbine vibration. Place your preferred po...
Step 9: Power Rod Construction
Because the turbine runs on little current, all metal surfaces—except the ionizer edges—must be smooth to reduce corona leakage. Begin power rod construction by drilling a 1/32” center hole about 1/2“ deep into both ends of each rod. Wrap the rods with chewing gum foil to make conductive jackets. Ensure that all edges are smooth.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
