-Samuel Bernier
Project RE_
“Submitted by DIN 2012, Université de Montréal, industrial design program, for the Instructables Sponsorship Program”
robot ipad clip5.eps546 KB
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I'm on a PC. Scanning the file, it seems to have been made on a Mac.
I'm assuming it may have some additional Mac file structure goodies
attached to it, which may be messing with reading it on a PC.
I tried a manual edit to fix the file, but I still can't open it in my image ware.
Is anyone else on a PC having trouble reading it?
Thanks again to Samuel for the inspiration!
Excellent Instructable! I whipped out a pair using a pine 1x2. I just cut out the shape (using my bench top band saw) and sliced the 1x2 length-wise to make two. I used your file (had to download FreeFileViewer to see it) as inspiration, but wanted a slightly different angle. I used an angle that seems like it will work in my most-used places ( work conference room, home dining room table) without glare. I used pine to make sure I like the angle. I will remake them out of some hardwood I have laying around after I am sure about the angle.
Great idea. Thanks!
can you save it in lower version such as ai8, so that everyone can open it.
I like your design.
thanks.
Sorry, but... what language do you speak?
If that is what you see in the file, have a look at it with Irfanview...
