Iphone Gopro Case
Introduction: Iphone Gopro Case
This case gives you greater stability while using your gopro with the gopro app than you would get with a lcd screen. The idea was originally based off of the GoPhone case, check out the Kickstarter link here: https://goo.gl/B1uCPp
Step 1: Start Out With Case
I started out with an iPhone 5 case, I have done this on many different cases such as the iPad mini, and Samsung Galaxy S5, you don't have to start out with an iPhone 5 case. I found many cases on thingiverse.com
Step 2: Add Gopro Mount
I found some models of flat gopro mounts and added them on top of, but sunk into the case. Here's just one of the mounts I found: http://www.thingiverse.com/thing:316600
Step 3: Decide How to Print
My Makerbot Replicator 2 would need to make supports to print correctly, and it would be a pain to take the off, so I chose to use shapeways, and that cost me roughly $20. Here's the link to buy the iPhone 5 case: https://goo.gl/qZhgqX, I will be adding newer phones soon.
Step 4: Getting the Case From Shapeways
This is my favorite part of it! The case fits both the gopro mount and the iPhone perfectly. I put my Gopro on Wifi mode and now have full control of it right from my phone. Don't forget to vote for me in the 3d printing contest!
Step 5: The Test
Testing if it works. It is best to have the gopro between your pointer and middle finger to have greater stability while shooting. Here's the link to the video: https://goo.gl/1Y9lfO
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    No *ucking way! Thats what I thought about doing. The point is that you can film with your go pro while watching in the camera app. As i don't want to spend $100+ for the LCD backpac this comes in handy. And the camera is more steady, as it has the weight of the phone too, plus you have a handle!
    Thank you, I should've put that in my description.
    why would u need a gopro mount if u have a camera
    Because first of all the gopro camera has a higher megapixels amount and if you are recording somebody skateboarding you would want to get a view of the skateboard right?
    Great idea. Thanks man.
    No problem bcoetzer.
    Why would you need 2 cameras? You already have a phone camera. Make a case that has a go-pro compatible mount so you can put your phone on go-pro mounts.
    I'm not sure I understand the point of this.
