3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ipod Touch Charger, 100% works
Step 6Working :D
Working :D
Here is the final circuit :)
7 comments
Nov 6, 2010. 7:56 PMnelsonguitar says:
Very good idea ,I try to charge an iPod touch using an iPod classic charger
and it didn't work
I found your tutorial and saved £20
Nov 8, 2009. 11:30 AMredsox14 says:
Used the same circuit, but with solar panel for my ipod touch 1st generation and did not work.  Multi-meter reads 5v output.  Any suggestions?
Jan 5, 2010. 4:06 PMdark sponge says:
 Does your solar panel put out enough current (ma)? If it does not have enough, the voltage drops when the load is connected.
Sep 2, 2010. 2:09 PMraykholo says:
Add a 5.5v supercap so that the system will have some reserve current. You will need a diode, preferably a low dropout one to maximize efficiency.
Aug 6, 2009. 1:43 PMSchuscod says:
Can u use a ac adapter 5 volt instead dc and can u use any resistors
Oct 27, 2009. 3:22 PMChromatica says:
If you do, you need to ad a rectifier
Nov 2, 2009. 4:46 PMChromatica says:
add*
Jun 10, 2009. 4:36 AMstevepoole63 says:
Thanks for that, I didn't have 150K, 100K worked fine. Next I have to get it hooked up to solar power.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Gokhan
