3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ipod USB Charger
Ipod USB Charger
the Apple brand ipod charger is outrageously expensive. i bought my 1st gen nano from a friend for $50, the Apple usb charger is $39.99. to make this unit, i will show you how to take apart a dc wall adapter without ruining it.
Step 1Opening the wall wort
opening the wall wort
opening these can be quite difficult. i found that cutting of the cord at the base and prying the case apart is the easiest method.
I used a chisel to slice the cord at its base, no damage to the case.
As you can see in the photos the chisel is facing away from the plastic so it doesn't gouge it.
18 comments
Aug 20, 2009. 8:47 PMpancho del rancho says:
how much waz dat thing with the wheel
Oct 16, 2011. 11:49 PMacoleman3 says:
that "thing with the wheel" is a dremel with a cut off disk. depending on how many speeds it has or how many accessories it comes with, they can range from i believe 19 to the mid 40's at walmart. on a more personal note? learn how to spell mate. ive seen 2nd graders who spell better then that.
Jun 3, 2009. 4:51 PMtbakhsh says:
I have a modded wall wart, it originally lets out 5v, so i just put in a usb cord. it charges other usb things fine (psp) but it wont charge my ipod touch. it worked when the ipod had an extremely low battery. like it wont let you do anything, only shows a battery. but when it turned on, it stopped charging.
Jun 25, 2011. 9:15 PMpyromaniac_alert says:
You might not be running the right amount of current for your particular ipod. Try searching for the power rating of your ipod.
Feb 14, 2009. 4:04 PMAndruha1123 says:
can someone please tell me, what pins are used to charge video ipod 30gb, 5th gen. i bought one on amazon, and it doesn't work, it does have connector tho, so i might make it work if i know what pins are used to charge. thanks in advance!
Aug 3, 2008. 1:10 PMterd_ferguson says:
it is possible to stab yourself with a screwdriver. trust me
Jan 3, 2009. 11:31 PMorangesrhyme says:
You know this from personal experience, huh?
Jan 6, 2009. 6:53 AMterd_ferguson says:
Yeah, sadly. but I've learned from that mistake.
Mar 7, 2008. 8:54 PMalex-sharetskiy says:
yay hot glue!
Dec 25, 2007. 8:15 PMmickoc says:
you might want to mention in your instructable that the wall wart has to be 12v or less, depending on your regulator. or is the highest voltage wallwart 12v?
Dec 24, 2007. 10:45 PMxnifx says:
or you can just go to Big Lots! and buy one for $4.99. Thaaat's right. And it FOLDS UP TOO!
Dec 24, 2007. 11:47 AMdchall8 says:
I missed something. Where did you get the regulator originally? Is that something you get at Radio Shack or do you have to make it?
Dec 24, 2007. 12:49 PMtysonscott2002 says:
he got the regulator from a previous project (the car charger), but you can buy those at radioshack. im still not clear on where he puts it in the curcuit though..
Dec 24, 2007. 11:41 AMGorillazMiko says:
wow, great instructable! and i love that song What I've Done.. i listen to it all the time :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:llamafur
