3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ipod touch speaker dock
i took an old speaker a two way male headphone jack and a cacet case.
Step 1Materials
materials
speaker with speaker wire keep in mind an ipod cant run a huge speaker.
caset case for dock(optional)
two way male head phone jack
duct tape
hot glue and hot glue gun
11 comments
Nov 11, 2010. 5:23 PMemihackr97 says:
they have inveted a wonderful thing called FULL STPOS, use it!
Aug 9, 2011. 9:25 AMhsarode1 says:
I did not want to put it coz i had no tym k.
Aug 9, 2011. 8:09 AMhsarode1 says:
Hey i will tel u clearly tat 1st pin the largest 1 is the ground pin then the middle is the Right audio signal and the last 1 is the left audio signal so he is asking us to connect ground and Left audio signal to the speaker usually there are three wires in the 3.5mm audio jack 1 is white 1 is red wire and the other 1 is the copper wire the white is left and the right is red and the copper is ground. So u must be thinking that usually there are 3 wires and there are 2 speakers so where is the 4th wire??? look we call the ground wire as negative and the left or right audio signal as positive so with 1 speaker the white wire goes with the copper and on the other speaker the red wire goes with the copper this is how it is arranged what they do is there are 2 negative wires so they make it 1 but u can join left and right audio signal like that because u r using 2 speakers even if u use 1 the same rule applies
Jul 3, 2009. 7:44 PMToon_ca7 says:
OUTPUT OVERDRIVE
This doesnt affect your iPod by demanding an output override in the iPod itself?... I mean, I dunno how much power those speakers you use demand neither Im sure if those speakers docks arround the net have an altern amplifier to help the iPod.
Anyway I guess if you keep the volume in low-mid levels wont be problem... I guess U
Jul 11, 2009. 11:20 PMalex-sharetskiy says:
it's only like 8 ohms, it can't be that bad...
Jul 18, 2009. 11:52 PMToon_ca7 says:
You're right; I've check out the iPod features and so far it can handle 32 ohms so a single 8 ohms speaker wont hurt at all =)
Nov 11, 2010. 5:21 PMemihackr97 says:
youre wrong, it cand handle FROM 32 Ohms, not TO 32 Ohms it can be more that 32 Ohms, but not less or it WILL hurt.
Jan 12, 2010. 8:45 PM3VIL G3NIUS says:
 it will hurt it. you shouldnt run a amp at anything below rated ohmage or less. so nothing below 32 really. you might get away with 16ohms but it could still damage it.
Feb 27, 2010. 6:28 PMbobert610 says:
 dontcha need an amplifier?
Nov 29, 2009. 4:58 PMHa4xor4life says:
 Are you four? I mean, honestly.
Now I don't mean to be a Grammar/Spelling Nazi, but cmon'; you don't know how to spell sure?
Besides that, please clean this mess up, the 'ible itself is poorly written.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:payupsucka
