Ir Remote Controlled Home Applicatin Project With Fan Regulator
Published
Introduction: Ir Remote Controlled Home Applicatin Project With Fan Regulator
About: I am a part time hobbies and love to work with new projects
This project for those who have culture with arduino and projects,not for noob's
i made this as a project but i am using this for production purpose too...
for this cause i can't share all complete sketch...
Step 1: Gathering Everything...
let's gather some parts
arduino atmega168 or better
breadboard or vero board(if u wanna make it permanent)
7segment display (common cathode) for display regulator position
resistor... 1k,10k etc
cap 470/16, 104p ,22p etc
crystl 16Mhz
relay
relay driver (as per quantity of relay, 8max)
triacbt134 or bt136 (as per load)
diac
a push switch to reset
opto ldr (this is hand made , i will show you how to make it)
a working power supply (12v 2amp recomended for smooth relay driving)
ir sensor....any type will work (big one is preferrable for better recepsion)
remote (any standard remote will work, but you have to findout its hex or dec code for put it in our sketch)
led's (optonal)
Step 2: Lets Start...
lets assemble the circuit
connect the relay with driver
i will upload the circuit diagram later
you can use serease of leds instead of 7 segment display but there is changes in our sketch for this changes
for make the opt ldr you can take small led and ldr (it's better to use a small red led instead of use any other color)
you can use a shrink tube to make the opto-led(atleast i name it like that)
we did not use any zero crossing circuit to make it cheaper and reduce the sketch size and also make it easy to understand
Step 3: Lets Finish...
this is a very stright forward instructable ...
so if anyone hav any query then they can msg me ....
i cannot give the 100% ready sketch or code , instead of it i can help to built it
but i can give the circuit as well
Step 4: That's All for Now
again , if you have any question please don't hesitate ...
my fb id is https://fb.com/babludhaki
i 'll add my fb page later
i 'm a part time hobbiest and this project is for education purpose only...
Step 5: Schematic Diagrams
I uploaded a test program and also a schemetc diagram...
Microcontroller Contest
This is an entry in the
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    Cool remote design. I can think of a lot of projects that this could get worked into.
