Iris Furrows/ Surcos De Iris
Published
Introduction: Iris Furrows/ Surcos De Iris
About: Well, I,m Angel Yamil Ortiz Torres, I'm a writer that like and writes fantasy novels and like plants and education. I love to create and this is why I'm here. Let's make some Intructables!!
  I always loved the Iris plants. It's very resistant and longlasting, don't need many cares and its form make the think how useful could be the plant to make furrows. This could be used in gardens to create beautiful lines and even to fence an area. At the end, you should have a beatiful divider that will not require many cares and will surprise you with its flowers.
 Siempre me han encantado las Iris. Es una planta muy resistente y duradera. No necesita de muchos cuidados y su forma me hizo pensar en cuan útiles pueden ser para crear surcos. Estos, pueden ser utilizados en jardines para crear lineas e incluso cercar un área. Al final, tendrás  un hermoso divisor el cual no requerirá de muchos cuidados y  que lo sorprenderá con sus flores.
Step 1: Materials/ Materiales
Materials:
1. An area to make it
2. Many Iris plants
3. A knife or object to make a hole
 Los materiales que necesitas serian:
1. Un área para realizarlo.
2. Muchas Iris
3. Un cuchillo o objeto para hacer un hoyo
Step 2: Optional: Obtain Plants From Its Mother Plant/ Obtenga Las Plantas De La Planta Madre
After its flowering, the Iris plants usually have tiny plants, a perfect idea to obtain a lot of them. They are removed from the leaf and usually I cut the leaf because  they dry and fall to the sides.
 Las Iris después de su florecida usualmente tienen pequeñas plantas, que son la idea perfecta para obtener una gran cantidad de ella. Se sacan de la hoja y usualmente le arranco la hoja debido a que estas se secan y corren a los lados.
Step 3: Trace a Path/ Trace El Camino
Trace the path where you want to make the furrow.
Trace el camino en el que desea hacer el surco.
Step 4: Plant It /Siembralas
  Make some small holes on the path and put the Iris plants so that it stay upright. The closer you plant it the more faster the furrow would  be done.
 Hagan en el camino unos pequeños huecos y ponga las Iris de forma que se mantengan erguidas. Mientras mas cercas las siembres mas rápido se formara y se forrará el surco.
Step 5: Let Them Time to Grow/ Denle Tiempo a Crecer
Finally, give them time to grow. The more time they have the more beautiful the furrows would be at your garden or project. I hope you liked the idea.
 Finalmente denle tiempo a que crezcan. Mientras más tiempo les den más hermoso quedaran los surcos en su jardin o proyecto. Espero que les haya gustado la idea.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    muy buena informacion y explicacion para poder decorar en tu jardin con estas plantas que como aqui mismo dice pueden ser muy duraderas.
