Introduction: Iris Recognition on Zybo
This Iris recognition tutorial for Zybo will provide instructions on how to modify a consumer camera (webcam) for infrared acquisition and prepare Zybo board for running the Iris recognition app.
Required materials:
Zybo board;
Consumer camera(webcam);
USB hub;
VGA or HDMI monitor;
Keyboard;
Latest Xillinux release from Xillybus;
Step 1: Preparing the Webcam
Remove the webcams front cover to access the lenses.
Step 2: Remove IR Filter
Unscrew the lens from the sensor and remove the IR filter (red tinted glass) found on the inner part of the lenses.
Step 3: Adding IR LEDs
To enhance image quality two 850 nm Infrared LEDs must be added.
Make 2 holes in the front cover of the webcam and insert the LEDs.
Use an old USB cable for power. Solder the LEDs to the +5v volts and Ground wire of the USB cable. Batteries can be used instead of the USB cable.
Step 4: Block Visible Light
Next, we must block all visible light between the eye and the camera. A plastic pipe can't be used for this step. The length of the cover is given by the focal point of the camera after removing the IR filter.
Place the cover on the camera.
Step 5: Test Camera
Connect the camera to a PC/MAC and run a video app. Test if the image is in focus and well illuminated. Adjust the length of the cover accordingly.
Step 6: Preparing Zybo Board
Step 7: Connect All Peripherals
Connect the camera and the keyboard/mouse to the UBS hub.
Connect the USB hub to the ZYBO OTG USB port.
Connect the VGA/HDMI monitor.
Connect the Ethernet cable.
Connect the Power Supply.
Step 8: Booting Up Linux
Next power on the Zybo board and wait for linux to boot up.
Type startx to access the graphical interface.
Step 9: Installing SDL Library
Run apt-get install libsdl2-dev
If you don't have a package manager installed go to SDL2 website and download the latest source.
Unzip the archive.
tar zxfv SDL2-2.0.3.tar.gz
Run ./configure && make all
Wait for make to finnish and run:
make install
Step 10: Getting the Iris Recognition App
Step 11: Running the App
For checking a person against the database use:
./irisRec_v1 -d /dev/videoX , where X is the id of the connected camera(usually 0)
For adding a person to the database use:
./irisRev_v1 -d /dev/videoX -a "user_name"
