Iron Man 2 Swinging Sticks aka Double Pendulum
 by bloomautomatic
Contest Winner
Like many of you, after watching Iron Man 2 (which was awesome, by the way) I was very interested in the “Swinging Sticks” sculpture on Pepper Potts’ desk. A little bit of searching turned them up for sale. They could be mine for just under $300. If they were a whole lot under $300, I would have bought them. Instead I set out to make my own version.
Unfortunately, the one for sale runs on batteries, so this is not an exact replica of it.  This is more like a modified double pendulum.  Double pendulums are pretty cool by themselves.  Much has been written on them, including some pretty cool flash simulations
This is an entry in the Kinetic Sculpture Contest, so please rate it and vote on it when the time comes.
Step 1: Materials
At the minimum you're going to need:
Rods for the main beams - I used 3/8" diameter steel.
Bearings - sized to fit the rod
Rods for the axles - I used 1/8" diameter steel.
Drill press
Drill bits
Reamers
DavidMarks says: Feb 22, 2013. 6:28 AM
Tried to make one of these (unsuccessfuly !) before so I was very pleased to see yours. On thing worries me however. The dimensions you give for your final build don't seem to add up. If the overall length is 13 then surely the distance from the middle pivot to the end of the bar is seven & and three quarters.
minh123 says: Jul 3, 2012. 8:56 PM
it's so cool but i don't know where to find rod for the main beams :( can u help me?
minh123 says: Jul 3, 2012. 8:53 PM
i think that do it with the chopstick wil make it lighter
minh123 says: Jul 3, 2012. 8:51 PM
Spiky1987 says: Dec 17, 2011. 2:10 PM
Hi , i'm trying to do the 3d model of the arms and, the Long Arm. If you put the first pivot at 1/4 and the second 5" after, the End to pivot gives : 7.437 "
Did you inverse some measurement ? As I can see on your picture, the long arm has the second pivot at something like 6"
blinkyblinky says: Sep 28, 2011. 2:13 PM
Nice. To add batteries, simply install one magnet at each end and use this schematic. Actually, you should use a micro controller or incorporate a random generator to push it randomly. Very nice.
jeff-o says: Nov 28, 2010. 9:32 PM
Very cool. Did you do any research into what sort of mechanism could be made drive the pendulum? I guess it would be electromagnetic or something, running on batteries...
ben_xman in reply to jeff-oJul 31, 2011. 11:46 PM
You can certainly add something like this to it. I have actually made this circuit customly and I works pretty well. There is just an annoying beep everytime the capacitor releases its charge, but it should work.
http://www.solarbotics.com/assets/documentation/solarbotics_sunswinger_kit_jan082007.pdf
bloomautomatic (author) in reply to jeff-oNov 29, 2010. 4:18 PM
Yes, but I had no intention of adding that, so I didn't dig too deep. I assume it's electromagnetic. There are similar kinetic sculptures that rotate continuously - a jumping dolphin and a space shuttle/planet comes to mind, that are cheap enough to crack open to see what makes them tick.
Vince
jeff-o in reply to bloomautomaticNov 30, 2010. 4:25 AM
Yeah, I had one like that when I was a kid. I wonder if I still have it somewhere? Hmmm...
mikeasaurus says: Jul 8, 2011. 9:12 PM
Nice project, and the video is awesome. Good job on your craftsmanship, hitting close to that magic ratio is hard.
Have you considered LED's on the pendulum ends in a dark room? Might make a neat time-lapse, too!
aeray says: Nov 18, 2010. 12:22 PM
Nice four-fold rule. I use a 6' folder frequently, but I haven't been able to find a good four-fold yet.
bloomautomatic (author) in reply to aerayNov 18, 2010. 6:09 PM
Thanks. I think it's a Stanley #27, if memory serves. It belonged to my grandfather. Not sure how old, but the number style looks older than one I saw for sale that was supposed to be 1940. Wouldn't surprise me to find out it's from the 30's.
bloomautomatic (author) in reply to bloomautomaticNov 19, 2010. 9:31 PM
I guess my memory isn't that great! It's a "C-S Co. No. 68"
aeray in reply to bloomautomaticNov 20, 2010. 8:30 AM
I'll have to renew my search.
Kiteman says: Nov 18, 2010. 10:33 AM
Nice piece - I'm impressed that the base is bulky enough to hold it still in use.
bloomautomatic (author) in reply to KitemanNov 18, 2010. 6:10 PM
As long as you don't get too crazy with spinning it, it works fine. I should attach it to a larger plate - like 6" square, but I probably won't get around to that since it works well enough as is!
ChrysN says: Nov 18, 2010. 4:28 PM
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
