The faceplate is attached to a rotary slider mechanism (similar to an engine conrod arrangement) which pushes the faceplate out and then lifts it up by rotating the left ear piece. Then six blue 3mm LEDs and a few resistors are attached to a 9V battery and a switch to light up the eyes which are covered with some blue lenses from an old pair of fashion sunglasses.
It's a shame I didn't take more photos during the making process but it essentially follows the same techniques used by many to make Master Chief helmets. A couple of lessons I've learnt from this are: To make a paper helmet to check scale and then make it 5-10% bigger with the cardstock as the fibreglass and body filler make the shell solid and much tighter, so much so that this helmet is really difficult to put on. At least with a bigger helmet, you can pad it out. When making the card shell, don't crease folds that don't need to be creased, otherwise you're just making more corners you need to smooth with body filler, and that's a real pain.
I also made a quick Mark II arc reactor from a used tape roll, some card, copper power wire and a ring of plastic tube. It was supposed to go together as a Zombie Iron Man, but unfortunately not many had read that series.
EDIT: Here's the link to the 405th forum where I found the pepakura file (which came from League Of Heroes). The link is also down in the comments.
http://405th.com/forums/index.php?s=7d9a7af8c3cadec9462a9ff41ab2bbc3&showtopic=11841
For metal casting instructions try this link:
http://www.backyardmetalcasting.com/
Thanks,
m
to convert is to a PDF file. It's completely free! I used it, and now I'm going to go to staples and get me my cardstock copy.
I hope this helps!
here's one: http://thepiratebay.org/torrent/5138201/VMware_Fusion_3.0___Keygen
I'd say superglue is a bit much, and isn't that super on paper. A Pritt stick or other stick based glue would work well. Even a contact adhesive like Evo-stik would do. I just find using PVA too slow drying for the card and you spend too long holding pieces together. YMMV
