Iron Man Arc Reactor
Introduction: Iron Man Arc Reactor
Hello everyone, this is my first intructable and I hope you like it!Also I'm a really big marvel fan I decided to make a arc reactor for iron man 3!(this is mark 1)
Step 1: Materials
What you need - a strainer ( from the sink) - a aluminum net thing - a washer - staples - wire - some cardboard - some foam - hand light or camping light - batteries - double sided tape - hot glue gun
Step 2: Disassembly
First you unscrew all the screws at the back of the light and take off all the plastic.(you will need the plastic later!) and then put some blue see though material that I got from school.
Step 3: Strainer
Now take your strainer and cut small pieces of foam and stick them like the one in the picture.Then wrap wire around it as much as you like.I did it 4 times.
Step 4: Middle
Get your washer and stick it right at the centre and place your net on top. I got it from this(above picture).Then take a plastic ring and put it outside the washer.I found it in my toolbox(also above picture) and paint it black.Cut your staples so it becomes flat and stick it like the first picture.
Step 5: Back
Take the covering of the light and place it at the back so that it will give extra support and take the packaging of the light and cut it in half and put it at the back too so that the batteries won't fall out.
Step 6: Putting It All Together
Use your hot glue gun and glue the top to the body of the arc reactor and be careful! It's very hot.after that dries, cut out a long strip of cardboard and stick it around the arc reactor and you're done! Thank you for looking at my intructable!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
