Remove these ads by
Signing UpStep 1Equipment
EberhardFaber light weight air drying clay
Plaskti-kote super enamel 686 gold
Ford Jupiter red metalic spray paint
Clear lacquer
Craft knife
sand paper
wet and dry paper
A pair of old sunglasses
4 bright white LEDs (sold in car shops)
12v Battery
switch
![P250408_23.32[01].JPG](http://img.instructables.com/files/deriv/FU8/OJZO/FH0JOTSF/FU8OJZOFH0JOTSF.SQUARE.jpg)
![P170608_20.01[01].JPG](http://img.instructables.com/files/deriv/FMF/GPKW/FHJMUHKZ/FMFGPKWFHJMUHKZ.SQUARE.jpg)
(the iron man suit is great)
The first things I made were so ugly, they were not even close to what I had in my head. But ! I tried again. I played with clay and got better at sculpting the basic shapes I wanted; then I learned to add details and it just takes adding that little step of skill over and over and over. Soon you will find yourself cranking out a finish product that looks good and not even remember how you got there. Ya gotta build the body memory of the actions and then the mind can wander in the imagination.
See my earlier post above...
"Whatever The Mind Can Conceive, And BELIEVE, The Mind Can Achieve".
YOU 'can' do it. If you don't attempt it you will never know for sure and regret it later. Life is too short...make it happen.
As LARRY THE CABLE GUY sez..."GIT-R-DONE!"
It was a labor of childhood dreams though.
cheers
Is it best to try and carve out rough details such as the eyes before it dries?
If anyone questions stability and strength of Papier Mache...all I can say is that Movie Studios use it all the time. Life size horses made over armatures of wood and chicken wire have been made...saddle put on it and actors posing on it like a live horse. I once saw a used auto dealer that had a lifesize horse made and displayed out in front of his lot to draw attention from passing motorists...the horse was in a front legs up raised position...out in the elements of weather all year round. Yup...it's durable.
Taxidermists use it every day in their shops. I have a head I made once for a Ventriloquist figure ('dummy' as most folks call them)...which I made over a clay sculptured head I made (I am NOT a Sculptor by any means...just shaped it almost human life size by just just shaping it)...using a full 5-lb box of Modeling Clay.
Once it dried, I coated the clay with motor oil and applied the Papier Mache...let it dry for a week...cut it in half carefully with a sharp knife and removed it. The tip of one ear broke off the dried clay model as I was removing it but I just glued it back onto the head...still looks same as when I made it...some SIXTY YEARS ago. :-) Howzatt for durability?
The layers of saturated Paper are built up to the thickness you want.
I once made a large artificial rock for a model to sit on when posing for photos. They are LIGHT in weight and Stronger'n heck.
Good luck with your project(s).
~ ED
PS...I'm thinking of creating a ible on how to make and use the Papier Mache as professionals use it.
everything i've ever made from papier mache still looks like it was made from papier mache!
Here are updated photos of the 'finished' product. I ran close on time and the legs did not work out as well as I liked, but the whole thing was pretty good. A real pain to put on and take off, but such is the sacrifice to pay homage to shellhead.
I got really silly and decided to make it from metal & rivets. This is about 6 months work off and on. I don't know what I was thinking, but it has been fun too.
VC
The Mask could have been made for less than $5.00 US, as well as boots...easy when you know how, and it's not done with using expensive hard shrinking cracking clay.
"How?", you ask?
"Elementary my Dear Watson...Elementary".
~ Sherlock
The Prize?...
You're Reading it. :-) (Your Increased Knowledge.. Take care.
~ ED
The clay that you mentioned only comes in 250g packs, which seems very little for a project this big. However, their non-lightweight clay comes in larger packs.
- Is the lightweight aspect very important; ie would the helmet be unbearably heavy in ordinary air-drying clay?
- (Roughly) How much clay would you think is needed? It would be nice to know for cost and preparation reasons.
Thanks, and great build.
