3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Iron Man Helmet
Iron Man Helmet
Ok basically i wanted to make an iron man helmet similar to the one from the new movie! so thats what i did, i tried to take as many pictures along the way as i could showing the details and the changes that i made, as i went through trial and error to get the shape and size right. i've used light weight air drying clay and car spray paints thats about it i think?
Step 1Equipment
Equipment
OK these are the things you will need:
EberhardFaber light weight air drying clay
Plaskti-kote super enamel 686 gold
Ford Jupiter red metalic spray paint
Clear lacquer
Craft knife
sand paper
wet and dry paper
A pair of old sunglasses
4 bright white LEDs (sold in car shops)
12v Battery
switch
317 comments
1-40 of 317next »
Mar 13, 2012. 3:10 PMdmcawesome says:
go to youtube search 3d iron man helmet draw the face cut out ONLY HALF fold in half then cut out rest and you get a desent templet
Mar 13, 2012. 2:32 PMdmcawesome says:
can you make the cast of your head with paper mache like newspaper and school glue
Oct 11, 2011. 10:41 PMehhdean says:
I am going as Tony Stark for Halloween this year. I may add a mask.
Oct 18, 2009. 6:14 PMSunny124613 says:
You, sir, have a great talent.
(the iron man suit is great)
Sep 17, 2011. 4:45 PMpheadjack says:
if you are talking to Pheadjack, thanks man. I had a blast doing it. lot of sweat and sore hands, but it was worth it.
Nov 20, 2009. 7:08 PMskidude28 says:
I'm loving that green goblin mask. I really want to make one but I have no artistic skills whatsoever.
Sep 17, 2011. 4:42 PMpheadjack says:
I agree with 32033. just do it. even if the mask turns out horrible, you will learn things from the attempt and the next one will be better. I started playing with latex masks, ears, scars, neck bolts, and other things a long time ago.
The first things I made were so ugly, they were not even close to what I had in my head. But ! I tried again. I played with clay and got better at sculpting the basic shapes I wanted; then I learned to add details and it just takes adding that little step of skill over and over and over. Soon you will find yourself cranking out a finish product that looks good and not even remember how you got there. Ya gotta build the body memory of the actions and then the mind can wander in the imagination.
May 16, 2010. 3:12 AM92033 says:
"I have no artistic skills whatsoever"?
See my earlier post above...
"Whatever The Mind Can Conceive, And BELIEVE, The Mind Can Achieve".
YOU 'can' do it. If you don't attempt it you will never know for sure and regret it later. Life is too short...make it happen.
As LARRY THE CABLE GUY sez..."GIT-R-DONE!"
Jul 13, 2011. 10:17 AMhjfoster73 says:
Just curious, is that cardboard you're using to build the leg in the picture above? If so, what do you plan to cover the cardboard with and what type of cardboard is it? Awesome job, by the way!!
Sep 17, 2011. 4:35 PMpheadjack says:
If you are talking about the Pheadjack suit, these are all thin steel sheets, cut and riveted together. The whole thing weighs like 40 lbs and is a bear to get into. The main thing I didn't really take into account other that the time it takes to work metal sheets is the sharp edges. Had to roll all edges of each piece and still some are pointy.
It was a labor of childhood dreams though.
Jul 26, 2011. 2:20 AMagayon says:
Will you post a suit instructble? Great job with the Helmet
May 14, 2010. 4:36 PMscotty03 says:
do you have to put a material over the plaster base to stop the clay sticking to it? surely the clay would join with the plasticine?
cheers
May 16, 2010. 3:42 AM92033 says:
You can rub a light coating of oil or vaseline over the form with yout fingers, which will prevent sticking and easily removing when it's drying or dry.
May 19, 2010. 8:52 AMscotty03 says:
Thanks.
Is it best to try and carve out rough details such as the eyes before it dries?
May 20, 2010. 5:59 AM92033 says:
Yes. You could also do it afterward but easier cutting while the mask is still reasonably soft...while in the 'setting up' stage. Using good quality Papier Mache can make it hard like a football helmet when it's completed.  By giving the project a final spray of two or three coatings of Clear Lacquer or Varnish, it will be waterproof.
If anyone questions stability and strength of Papier Mache...all I can say is that Movie Studios use it all the time. Life size horses made over armatures of wood and chicken wire have been made...saddle put on it and actors posing on it like a live horse. I once saw a used auto dealer that had a lifesize horse made and displayed out in front of his lot to draw attention from passing motorists...the horse was in a front legs up raised position...out in the elements of weather all year round. Yup...it's durable.
Taxidermists use it every day in their shops. I have a head I made once for a Ventriloquist figure ('dummy' as most folks call them)...which I made over a clay sculptured head I made (I am NOT a Sculptor by any means...just shaped it almost human life size by just just shaping it)...using a full 5-lb box of Modeling Clay.
Once it dried, I coated the clay with motor oil and applied the Papier Mache...let it dry for a week...cut it in half carefully with a sharp knife and removed it. The tip of one ear broke off  the dried clay model as I was removing it but I just glued it back onto the head...still looks same as when I made it...some SIXTY YEARS ago. :-) Howzatt for durability?
The layers of saturated Paper are built up to the thickness you want.
I once made a large artificial rock for a model to sit on when posing for photos. They are LIGHT in weight and Stronger'n heck.
Good luck with your project(s).
~ ED
PS...I'm thinking of creating a ible on how to make and use the Papier Mache as professionals use it.
May 10, 2011. 10:53 AMtallpaul100 says:
Yes, definately please do an ible on Professional papier mache. Its the easiest cheapest thing to make but I've know idea how to get top quality results.
everything i've ever made from papier mache still looks like it was made from papier mache!
Feb 6, 2011. 8:11 PMTheRocket35 says:
Please do. I would love to learn. I think many on istructables would too.
Feb 8, 2011. 6:57 AMironman22 says:
nice work man i am just working on that mask and i gotta tell you it is not so easy it looks
Dec 4, 2010. 4:28 AMtechnofreak911 says:
I live in jakarta andi dont know where to buy clear laquer OR lightweight air drying clay. would you know any place where i can buy it?? if not could you tell me what would be the best possibe replacement??
Oct 22, 2010. 7:45 PMnefla24 says:
@ pheadjack. Great body work .... Eventually we'll have a working iron man suit haha!!! ...
Nov 5, 2010. 6:02 AMpheadjack says:
Thank you sir,
Here are updated photos of the 'finished' product. I ran close on time and the legs did not work out as well as I liked, but the whole thing was pretty good. A real pain to put on and take off, but such is the sacrifice to pay homage to shellhead.
Sep 10, 2010. 5:34 PMhifatpeople says:
make a metal suit, once youve done that, paint it, then add lighting wherever it goes.
Oct 28, 2010. 9:41 PMgodfathertrevor says:
It's not THAT easy...
Sep 27, 2010. 5:04 PMSeleziona says:
Where do you think you could buy the clay in Canada?
Oct 10, 2010. 7:35 AMBarrymore says:
You can buy it at Curry's art supply. As well they carry it at Michaels.
Oct 9, 2010. 6:23 AMpheadjack says:
I'm working up a suit as well. The instructables I have found here have been really great ! I appreciate all the help. Here are some images of what I have so far.
I got really silly and decided to make it from metal & rivets. This is about 6 months work off and on. I don't know what I was thinking, but it has been fun too.
May 16, 2010. 5:39 AMviam says:
 what if i used sculpey instead? would it be the same thing?
        VC
Jul 19, 2010. 6:26 PMstwrtlttl731 says:
sculpey is a polymer clay, which you have to bake after molding. It leaves a nasty chemical smell that takes a long time to fade, don't think you'd want that on your face :(. Once it bakes, it's basically like plastic. And you'd have to figure out how to adhere it to the plaster, unless you'd bake it directly on it.
Oct 23, 2009. 8:20 PMazerool says:
Iam from Malaysia... may i know where usually can get this Ebenhard Faber, actually what is this....
Jun 30, 2010. 1:05 AMrecvpics says:
You may get it from any art shop near Petaling Street (KL), MIA near Wangsa Maju (KL), One Utama Shopping Complex (PJ), Ikano (PJ), in Malaysia, most of the people recognize it as "Paper Clay", normally imported from Japan/Korea. around RM7 - RM 10 per pack, can't remember how big it was. Good luck.
Oct 4, 2008. 5:35 PMmunkeeboy says:
I absolutely love it. So once the clay dries, it stops shrinking right? That's the only thing that worried me, was spending 60 sum dollars only to end up wihta mask that won't fit anymore. I'm thinking of making a Mushroomhead mask, or a chris taylor mask. Maybe one of the masks from the Army of Two video game.
May 16, 2010. 3:51 PM92033 says:
I doubt anyone is following this link after almost two years from your asking the questions...I'll answer it anyway for future 'artistes' to ponder.
The Mask could have been made for less than $5.00 US, as well as boots...easy when you know how, and it's not done with using expensive hard shrinking cracking clay.
"How?", you ask?
"Elementary my Dear Watson...Elementary".
~ Sherlock
Jun 27, 2010. 10:31 PMnenaptio says:
yes how actually when i think about it "elementary" hmmm I GOT IT!! paper mache isn't it?
Jun 28, 2010. 10:44 AM92033 says:
BIBG-BING-BING-BING...You just won the Grand Prize for having the correct answer.
The Prize?...
You're Reading it. :-)  (Your Increased Knowledge.. Take care.
~ ED
Jun 18, 2010. 2:26 AMniki_miki5 says:
i appreciate you you did your best
Jun 6, 2010. 1:05 PMGeoff 117 says:
I love your helmet. I'm looking forward to seeing the whole suit. I had one question, though. I've seen some helmets with motors that open and close the front part and I was wondering if you could make an 'ible on that?
May 26, 2010. 8:50 AMAnotherBrowncoat says:
 I know this is an old thread, but I have a few quick questions, as I'd like to do something similar.
The clay that you mentioned only comes in 250g packs, which seems very little for a project this big. However, their non-lightweight clay comes in larger packs.
- Is the lightweight aspect very important; ie would the helmet be unbearably heavy in ordinary air-drying clay?
- (Roughly) How much clay would you think is needed? It would be nice to know for cost and preparation reasons.
Thanks, and great build.
Sep 24, 2008. 6:15 PMsupersam78250 says:
you should try making a mask from army of two. that would be badass
Sep 25, 2008. 7:08 PMsomerockenguy says:
May 16, 2010. 3:54 PM92033 says:
Howse come nobuddy sez: "Goodass"?  Hmmm.
1-40 of 317next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
92
Author:pmaggot
