Step 7Spraying and Finishing?
For the gold part i used gold enamel spray from halfords and for the red i used Jupiter red car spray paint.
first i sprayed the gold (about 5 layers) about ten mins in between layers once done leave to dry for about an hour or 2.
Mask off the gold area with masking tape and then spray about 5 layers of red, also this takes a little longer between coats about half hour so give yourself a day to do this! then leave for 24 hours.
once the red is lookin good and thick and shiny then remove the masking tape.
then spray coats of laquer all over both colours untill the gold and red are both looking shiny. leave to dry and then its ready to wear.
![P240408_17.03[01].JPG](http://img.instructables.com/files/deriv/FAY/NLM3/FGZYHACR/FAYNLM3FGZYHACR.SQUARE.jpg)
![P250408_15.29[02].JPG](http://img.instructables.com/files/deriv/F3N/N4CN/FGZYHACV/F3NN4CNFGZYHACV.SQUARE.jpg)
![P250408_20.25[01].JPG](http://img.instructables.com/files/deriv/FZV/SXHG/FH0JOTSH/FZVSXHGFH0JOTSH.SQUARE.jpg)
![P250408_23.32[01].JPG](http://img.instructables.com/files/deriv/FU8/OJZO/FH0JOTSF/FU8OJZOFH0JOTSF.SQUARE.jpg)
If you "think you can't"...you can't...
SUBCONSCIOUS MIND at work within you.
"Whatever The Mind Can Conceive, And BELIEVE, The Mind Can Achieve"
The optimum word is "BELIEVE"...
The Law Of Nature at work within you.
