3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Iron Man MkV Arc Reactor
This reactor, like my previous reactor, is available for purchase, visit my website and email me from there, the paypal links are now available for both styles of arc reactor
http://sites.google.com/site/msraynsford/ironmanarcreactors
Feb 2012 Green Arcs Kit's and Assembled
Having just seen the trailer for the new avengers film out this year I'm now pleased to offer the MkV in green for kit versions and fully assembled versions
May 2010  DIY Kit available
This arc reactor is soon to be made available in kit format. So if you ever wanted to make your own but couldn't make the parts yourself, now you can buy a kit containing all the parts, instructions and shaped polymorph.
Step 1Tools and Materials
Tools and Materials
The Materials
LED's
Resistors 180R and 330R
Polymorph plastic
4mm plywood
Red and black wire twisted into a length
Kynar Wire
9V battery clip
Heatshrink
An old DVD case
The Tools
Hot Glue Gun
Soldering Iron
Wood Router
Needle nose pliers
Wire Cutters, side cutting
55 comments
1-40 of 55next »
May 26, 2012. 8:18 PMDemonKing97 says:
Nice Reactor. But i kinda lack of the wood to hold the LEDs. Can anybody tell me other materials that can hold the Leds in place. I thought of foam but if solder, it will give out some Chemical thing........
May 15, 2012. 4:15 PMluseylottay says:
This is an awesome tutorial! Any chance of finishing it?
May 16, 2012. 1:23 PMluseylottay says:
Aww, okay then.
Apr 27, 2012. 7:57 PMpreeceindustries says:
sweet arc reactor. you know what I going to make it
Apr 4, 2012. 5:39 PMTitanium Rainbow says:
Awesome arc reactor
Sep 25, 2011. 3:01 PMelemastur says:
where can i find the leds you used and how do i circuit them?
Aug 9, 2011. 9:54 PMjcordova3 says:
someone can help me? would you translate me the materials and tools thank you
May 15, 2010. 6:41 AMAlexJ08 says:
what if your a child
mark-anthony
Jul 16, 2011. 12:38 PMpatriots8888 says:
what if your a bean
michael-jackson
Oct 25, 2010. 9:44 PMOnay91 says:
How do you suggest going about attaching this thing to your chest? I was thinking a necklace, sown onto a shirt, or possibly some sort of body glue. What do you think?
Nov 18, 2010. 2:37 AMtobyscool says:
I found on other instructables they stick it on belts
Oct 27, 2010. 12:12 AMmonkeys98 says:
Would glass work for the light to shine through on the front because i have a piece of glass that is the perfect size and shape.
Sep 1, 2010. 10:53 PMuvesh says:
interested in this thing give more details about it
Jul 8, 2010. 7:26 PMbenha94 says:
ok, couple of questions. they look to be wired in series, do you need the resistors to keep them all the same brightness or can you wire them in series without any resistors and have them all the same brightness? would mounting them on balsa wood work? thats all, thanks
Jun 10, 2010. 9:35 AMWarmachine11 says:
just kinda cool but mine is better
May 28, 2010. 2:41 PMMITisNOTHINGtoME says:
Where's the rest of the instructable?
May 13, 2010. 5:35 PMtrauma-d says:
Do you have to use surface mount leds or would regular ones work?
Jun 2, 2010. 9:25 PMafreeland says:
You can use standard LED's but as msraynsford said they have a lot more depth than the surface mount led's....I made a couple of arc reactors using some white water clear led's and just made sure to sand them down so that the light was properly diffused and they looked pretty decent....if you would like to see how a sanded led looks in comparison here is how mine turned out www.afreeland.com/node/29 ...hopefully this helps
I also must say that this is an amazing tutorial and must admit that your work is amazing!!!! Keep the great LED content coming =)
Jun 4, 2010. 12:06 PMtrauma-d says:
thanks, looks awesome.
May 13, 2010. 11:03 PMITAstallion13 says:
ok great, when will the pay pal link be up for the mkV kit? you did a really excellent job putting these together
May 18, 2010. 7:55 AMlonewolfkliq says:
Wow.
I seriously want to make this one.
I may buy the kit from you or even just buy a completed one as soon as I have some extra cash.
Awesome stuff.
And your stuff is especially great cause your reactors aren't like 4 inches thick which completely ruins the movie realism.
1000 thumbs up!
May 13, 2010. 11:33 PMblaqkout says:
 where did you get your leds?
May 14, 2010. 6:41 PMdeath2602 says:
Guessing he got them here www.rapidonline.com
May 12, 2010. 8:37 AMtrauma-d says:
this thing is awesome! Great Work! Do you have like a video to show how to make it?
May 13, 2010. 5:03 PMtrauma-d says:
Never mind about the design i over looked the design you already provided.
May 13, 2010. 2:17 PMreoga13 says:
 i like it it is a much sleaker disign but it just seems like a led array behind som wax or acrilys and a template on front to block some light...i personaly like the older disigns where the is a challacnge presented in constructing it
May 13, 2010. 8:35 AMtrauma-d says:
Not really anything in particular. I was just wondering a few things like details on leds and resistors and how they are wired. I've never really wired multiple leds i have made a few projects here and there but never really done anything quite so extravagant but REALLY like this so I wanna give it a try. also did you get the design off the Internet somewhere or something I could print off or look at from a birds eye view?
May 11, 2010. 10:52 PMmettaurlover says:
As for the outer triangle, you could try relocating the LEDs to the corners and double the LEDS in the center-then those would light up the middle of the sides while the relocated ones at the corners would light up the rest.
May 12, 2010. 5:19 AMmettaurlover says:
Yeah... If you just relocate the ones currently in the outer triangle, they should light up the entire thing while allowing for a better wiring plan. I assume you are familiar with the method of putting LEDs onto two rings of wire with one terminal on each, and the same terminal for each? If you used insulated wire here, that method would make wiring look much neater as well as letting you put in as many LEDs as you need.
May 12, 2010. 7:11 AMmettaurlover says:
It's pretty much like this:
____________
O O O O O O O
But closed on both ends; the O's stand for LEDs and you attach the - leg of every LED in the set to one ring and the + leg to the other ring. Simplifies wiring and allows you to easily make changes to the position fo the LEDs.
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
125
Author:msraynsford
