Iron Man ARC Reactor
24,606
131
8
Posted
Introduction: Iron Man ARC Reactor
I'm ready for holloween!
This instructable will teach you how to make a cheap 3" iron man arc reactor mark 4 prop for a costume
Step 1: Creating the Face Pieces
This is the trickiest part because it requires patience and proper measurements (on your part). this is creating the face of the arc reactor. the face consists of 5 pieces; the large triangle, the smaller triangle(fits inside of the larger triangle), and the three "v" shaped pieces(that fit under the larger triangle).
       i used Tupperware lids to make the cutouts. In order to get the larger and smaller triangles i went to google images and searched "perfect triangle" and then printed out the proper size triangle for the 3" arc reactor.
i was careful that the larger triangle fit perfectly into a 3" circle. and the smaller triangle fit in the middle of the larger triangle.
       i cut out these parts with an xacto knife. i found that the "v's" were the hardest part. i have given pictures of my templates. it's up to you to decide on the measurements of the pieces.
once you have the pieces cut out you will need to sand them down and paint them. i used metallic silver krylon spraypaint.
Step 2: LIGHTS!
I used a 24 led light strip blue(bought on ebay for  $7.49), a 12v dc battery pack(bought at radio shack $3.99), and a 9v battery adapter(optional, also radio shack $3.49).
Step 3: Outer Casing
       There are a wide range of casings you can use to finish this project but i found a very simple, if not the simplest way to do it.
i bought a piece of pvc piping called a 3" bushing. IT HAS TO LOOK EXACTLY LIKE THE ONE IN THE PICTURE in order for it to work!
and i bought a 3" pvc traansparent cap. (both were bought at lowes $6.00)
i Dremeled the edges of the clear pvc cap down until it fit snug down into the 3" bushing then i glued it in place.
then i took the bushing and trimmed it down(with respect to the internals you're about to install.)
Step 4: Putting It All Together
     Now its time to put everything together. the face is simple just copy what i did in the pictures in terms of positioning an gluing.
NOTE: the larger triangle is glued onto the bushing while the other face parts are glued onto the transparent pvc cap.
now for the internals. position your led strip on the inside any way you like. i wanted my light focused in the center so i wrapped the led strip in a tight circle and taped it together with clear tape. then positioned it in the center
to diffuse the light and hold the led strip in place i injected clear silicone caulk all around the led strip.
once the glue and silicone has dried, you have yourself an impressive looking arc reactor prop.
i hope that this instruactable  has answered all of your questions. if you are having any trouble, or i did not give enough advice please feel free to ask any question you may have.
Thank you :)
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
8 Comments
Can we use any other material other than tupperware lids in part 1?
Great job :) it will help me ;) thankz
Hi, how do you make it stick to your shirt? :)
I had an undershirt and i applied velcro to the arc reactor and under shirt. Then i took a regular shirt and cut a hole in it.
Could you explain the second part(the lighting) a little bit more? I don't understand what you're supposed to do. Thanks. And about the 12 V battery pack thing........... Is it actually just two 6V batteries together? Thanks again :D
hey sorry for replying so late. the 12 volt battery pack was bought from radio shack. it holds 8AA batteries, to wire the led's all you have to do is straight wire it (positive contacts, negative contacts.)
I was looking for a good arc reactor for Halloween and I'm pretty sure it's this one.
thanks! if you have any questions please ask. :)
