Iron man arc reactor
 by boltoms
This instructable will teach you how to make a cheap 3" iron man arc reactor mark 4 prop for a costume
Step 1: Creating the face pieces
This is the trickiest part because it requires patience and proper measurements (on your part). this is creating the face of the arc reactor. the face consists of 5 pieces; the large triangle, the smaller triangle(fits inside of the larger triangle), and the three "v" shaped pieces(that fit under the larger triangle).
       i used Tupperware lids to make the cutouts. In order to get the larger and smaller triangles i went to google images and searched "perfect triangle" and then printed out the proper size triangle for the 3" arc reactor.
i was careful that the larger triangle fit perfectly into a 3" circle. and the smaller triangle fit in the middle of the larger triangle.
       i cut out these parts with an xacto knife. i found that the "v's" were the hardest part. i have given pictures of my templates. it's up to you to decide on the measurements of the pieces.
once you have the pieces cut out you will need to sand them down and paint them. i used metallic silver krylon spraypaint.
jamesthecreator says: May 16, 2013. 5:35 PM
What materials were used?
OldSchulNikes says: May 2, 2013. 3:37 PM
Can u list of all the materials needed please?
The True Iron Man says: Apr 30, 2013. 8:00 PM
This is the simplest arc reactor I have seen yet! Awesome job. About how long it the led strip?
MicRoscope17 says: Apr 22, 2013. 6:58 AM
what are the materials?
amandaghassaei says: Nov 16, 2012. 1:37 PM
good to see this laid out in step by step form. will you be building any more parts for this costume?
boltoms (author) in reply to amandaghassaeiNov 18, 2012. 5:19 PM
i do have a repulsor arm. but i don't have any plans on building anything else.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
