Irrigation Timer, 4 Zone, With Inviot U1, Arduino Compatible
595
12
Posted
Introduction: Irrigation Timer, 4 Zone, With Inviot U1, Arduino Compatible
An irrigation system using the
U1 board from InvIoT.com.
The only hard part of this project is to connect the values, the 24v power supply, and the InvIoT U1 together. There are 2 ways to do that. The fist way is to use a 4x relay module. The other way is to build your own PCB with mosfet and a power step down from 24v to 9-12v for the InvIoT.
Step 1: What You Need....
1. InvIoT U1 board from www.InvIoT.com
2. a FDTI232 USB to UART programmer or any other programmer
3. USB cable
4. latest verstion of arduino IDE
5. Library for U1. Download the latest library from U1 library. Online manual, more examples and help for all the functions that can be used in the library can be found here.
6. A 24v power supply
7. 4x water values
8. A step down from 24v to 12v, or a 12v power supply
9. 4x relay module
Step 2: Load Software on InvIoT U1
1. connect FTDI
2. install latest verstion of arduino IDE and the InvIoT library Download. Info on how to install can be found at InvIoT.com 'softare setup'. Manual for all the functions of the library, more examples, and help can also found.
3. on arduino IDE goto File->Examples->InvIoT->g.Applications->irrigation->Run first EEPROM upload
4. press upload and open the Serial terminal. This sketch uploads all the strings to the EEPROM. ATMEGA328 has a low memory size, and all the strings that are used will take up all the memory.
5. on arduino IDE goto File->Examples->InvIoT->g.Applications->irrigation->Program.
6. press upload to upload the final sketch to the InvIoT U1. You are done uploading the software. Work with the menu and test the pins D2,D3,D5,D6. Those are the 4 pins used for the 4 valves. Every module is different
Step 3: Relay Connection and Power Connection
Connect your relays with the arduiot by using the pins D2 D3 D5 D6. Do not forget to connect the ground of the relays with the ground of the arduIoT U1.
On the switch side of the relay connect the valves and the 24v power supply. Google for more info how to connect a device to a relay.
Power up the InvIoT U1 with 12V. I use a step down module from 24v to 12v. That way I have only a 24v power supply.
Step 4: For You to Do
On the U1 there is a wifi ESP8266 plug, so you can update the software to work the menus over the internet.
Don't forget that there is also a nRF24 plug. So if the values are far away from the U1, you can send the signals for each valve wireless. You can use any arduino with an nRF24 module and a 4 relay module on the remote site.
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    2 Comments
    like your program as well realy nice peace off programing
    like your setup
